New Member With a Rim Question - Mustang Evolution
Old 07-20-2014, 02:20 PM   #1
HORNET1's Avatar
Question New Member With a Rim Question
I am wanting to install a set of OEM 19" rims off a 2013 Mustang onto my 2003 Mustang. I know the spacing is different and I want to know what size spacers will be required. Any help will be appreciated.
2003 Base Convertible, 3.8 V6, Auto, One Owner, 56k miles, Leather Interior, Cat Back Duals, Cold Air Intake.
HORNET1 is offline   Reply With Quote
Old 07-20-2014, 04:44 PM   #2
I do not recommended, but if you must, answer below.
To fit the 2013 wheels on your 2003 Mustang, you would need 1-inch wheel spacers. Additionally, you will need to run a 26" tall tire instead of the 2013 stock 27.7" tall tire, otherwise you will have rubbing on the front when turning.
Now let's quickly cover the types of spacers:
-slip on (need longer wheel studs over 1/4"
-slip on with hubs
-bolt on
-bolt on with hubs
If you are going to install thick wheel spacers, then I highly recommend bolt-on spacers with hubs. The hub allows each wheel to remain hub centric compared to lug centric. Having the wheel centered by hub helps to prevent wobble/shake issues, especially when used on the front of the older Mustangs not designed for high offset wheels.
Do a quick Google search for, 1" wheel spacer mustang, and review all the types in the links. You will see all four types I mentioned above, and as usual, the best type costs the most.
kn7671 is offline   Reply With Quote
Old 07-20-2014, 06:27 PM   #3
HORNET1's Avatar
Thanks for the info and advice.
WTT/WTB .... Rim or Rim & Tire swap back n a stang Mustang Parts for Sale and Wanted 0 10-19-2012 03:47 PM
Rim Question? Bobby88Stang 1979-1995 Mustang GT 16 05-01-2012 12:21 PM
Rim question! GTstang07 2005-2010 Mustang GT 19 09-28-2011 08:29 PM
1998 gt rim question eddie1 1996-2004 Mustang GT 19 11-08-2008 10:25 PM
Another 20" rim question wrecked2001 Mustang Wheels & Tires 8 07-16-2006 05:11 PM
01:32 PM
