MT82 Drag Setup. - Mustang Evolution
Old 08-26-2014, 06:49 PM   #1
Oh2freshstang's Avatar
MT82 Drag Setup.
I'm fairly new running at the track..I go around once a month & I'm trying to get some wheels to use at the track & I understand I want bias ply tires for the manual tranny. I wanna just get some rear bias ply tires to throw on but I'm hearing that it's not recommended to run bias ply's in the back with street tires up front is that true? I really don't want to have to get front runners as well as rear wheels/tires. Is there any other options I have? Will running a drag radial with the MT82 be another huge no-no?
Thanks for any info guys!
Old 08-27-2014, 03:57 PM   #2
Old 08-27-2014, 05:05 PM   #3
Getn off's Avatar
I have read we should not, but I will just say....
I have hundreds of passes on MT drag radials on my old GTO with the T-56 with zero issues. Well, zero issues with the tranny. Grenaded a half shaft once on street tires tho!! I plan on getting a set of DRs for my Mt-82 tracpac soon. Good luck.
Troy
Getn off is offline   Reply With Quote
Old 08-27-2014, 06:10 PM   #4
Originally Posted by Getn off View Post
I have read we should not, but I will just say.... I have hundreds of passes on MT drag radials on my old GTO with the T-56 with zero issues. Well, zero issues with the tranny. Grenaded a half shaft once on street tires tho!! I plan on getting a set of DRs for my Mt-82 tracpac soon. Good luck. Troy
I would much rather get bias ply radials but I heard it's bad to run them w/o bias ply's up front! I'm thinking maybe some DRs & just take it easy on the launch idk.
Anyone know what's the issue with running bias ply tires out back & street tires up front??
Old 08-27-2014, 06:14 PM   #5
I'm not a drag racer and don't have any experience with bias ply tires first hand. But I don't see why it would be bad to run bias ply in the rear and regular up front.
Old 08-27-2014, 06:38 PM   #6
Black12's Avatar
Bias ply is correct. Shifting that MT82 above 6500 will be your biggest issue. About 30% of the time it just won't shift. Ford did put a fuel shut off to save the deal so have at it and good luck. What you'll really notice is the lack of pull in 2nd gear. It's a tiny engine. Needs about another 50 lb. ft. of torque.
Black12 is offline   Reply With Quote
Old 08-27-2014, 07:09 PM   #7
Rapinator126's Avatar
^ :what:
Old 08-27-2014, 07:11 PM   #8
This is what I run on dig nights.
Perfect at the track also.
http://www.americanmuscle.com/mickey...rag-slick.html
Old 08-27-2014, 10:19 PM   #9
I'm not a drag racer and don't have any experience with bias ply tires first hand. But I don't see why it would be bad to run bias ply in the rear and regular up front. Bullitts are better than Bullets
Yea I don't see what the issue could be either. I read something about the bias ply sidewall & street tire sidewalls being different & causing the car to lose control? I don't know of that's right tho that's what I'm trying to figure out!
Old 08-27-2014, 10:21 PM   #10
Originally Posted by Rapinator126 View Post
This is what I run on dig nights. Perfect at the track also. http://www.americanmuscle.com/mickey...rag-slick.html Sent from my SAMSUNG-SM-G870A using Mustang Evolution mobile app
What do u run upfront Rap?
Old 08-28-2014, 05:46 AM   #11
245/40/19's
Old 08-28-2014, 06:01 AM   #12
245/40/19's Sent from my SAMSUNG-SM-G870A using Mustang Evolution mobile app
So there's no issues running street tires up front & slicks out back?
Old 08-28-2014, 06:21 AM   #13
No. I do not run them on the highway at 80+ though.
They are strictly for dig nights.
Old 08-28-2014, 06:48 AM   #14
No. I do not run them on the highway at 80+ though. They are strictly for dig nights. Sent from my SAMSUNG-SM-G870A using Mustang Evolution mobile app
No I meant what tires do u run up front at the track with the slicks out back on dig nights?
Old 08-28-2014, 06:52 AM   #15
Mickey Thompson street comps
Old 08-28-2014, 06:55 AM   #16
Mickey Thompson street comps Sent from my SAMSUNG-SM-G870A using Mustang Evolution mobile app
Ah ok. That's what I'm trying to find out! If I can run my regular street tires up front & throw some slicks or bias ply tires when I go to the track! I heard it wasn't recommended to do that, u've never had any issues?
Old 08-28-2014, 07:02 AM   #17
No, (Compstall is going to be here in a secound lmao, bc you said issues )
Old 08-28-2014, 08:15 AM   #18
No, (Compstall is going to be here in a secound lmao, bc you said issues ) Sent from my SAMSUNG-SM-G870A using Mustang Evolution mobile app
Cool thanks Rap!
Dam & it was the last word..can I take it back compatall? Haha.
Old 09-03-2014, 12:26 PM   #19
Would these work good with my m6 5.0? I have 3.31 gears.
Old 09-03-2014, 09:46 PM   #20
I have a chance to get some cheap 16 wheels. Would a 26 in tire (above) work good with my 3.31 gears??
Old 09-04-2014, 08:21 PM   #21
Old 09-06-2014, 04:28 PM   #22
lindertw's Avatar
I ran 17" M/T et street bias ply tires with my OEM front radials with zero issues. The sidewall on the 17" (or 16" that you're considering) isn't enough to cause much wobble...
26" M/T et street bias or Hoosier QTP bias are the way to go. I managed 1.65 60' times (with ~100 less HP than you)
2005 GT, N/A 302rwhp/317rwtq, 3500 lbs
12.095 @ 111.08, 1.576 60'
lindertw is offline   Reply With Quote
Old 09-06-2014, 07:16 PM   #23
Originally Posted by lindertw View Post
I ran 17" M/T et street bias ply tires with my OEM front radials with zero issues. The sidewall on the 17" (or 16" that you're considering) isn't enough to cause much wobble... 26" M/T et street bias or Hoosier QTP bias are the way to go. I managed 1.65 60' times (with ~100 less HP than you)
Cool man appreciate the info! Thanks!
K springs with drag setup BaSohol 2005-2010 Mustang GT 7 03-15-2013 04:24 PM
Best drag racing suspension setup? black9D5 2005-2010 Mustang GT 1 01-07-2013 09:09 PM
Drag bash london drag strip in ky. This sunday 4/29/12 H.A.W.K At the Track 1 04-30-2012 01:37 AM
For Sale: Bad A** Sonic blue Terminator, Drag setup drusmith FYI Ads | Recently Listed 15 08-09-2011 07:18 AM
best suspension setup for drag BrooksPS Pre-2005 V6 Mustang 2 03-11-2004 09:09 PM
09:18 AM
