Can I run wider tires? - Mustang Evolution
Old 09-23-2014, 09:31 PM   #1
Region: Arkansas
Ok I have a 12 GT with American muscle wheels that are 10" wide in the back. Right now I have Nitto Invo 275/35/18 on the back and I was wondering what is the best size tire for the 10" wheel. My goal is the widest tire in the back without effecting cornering. Please help as I am lost. Thanks
Wildstang86 is offline   Reply With Quote
Old 09-23-2014, 11:15 PM   #2
Old 09-24-2014, 01:22 AM   #3
Region: Arkansas
305
I wonder if going from a 275 to a 305 will actually help me get a little more bite or if it would be just a cosmetic change? And would it be ok to run a 305 out back and keep 255 up front?
2012 GT Mods:
JLT 3
BBK headers w/ o/r/x
MGW Shifter
Eibach lowering springs w/ LCA's
Brenspeed dyno tune
404/381 to the ground
Old 09-24-2014, 02:44 AM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
305s are approximately 30mm wider (depending on the tire manufacturer), so yes, you'll get more bite out of them. Each tire's contact area with the road is gonna be increased which translates to more traction.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 09-24-2014, 03:39 AM   #5
Region: Arkansas
Thanks for your input. I just wasn't sure if it was enough to justify the cost of increasing tire size. And 305's won't have to much sidewall for corners?
2012 GT Mods:
JLT 3
MGW Shifter
Brenspeed dyno tune
Old 09-24-2014, 05:27 AM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It all depends on the tire. 305/25/18 would have less sidewall than 305/30/18. That middle number will be what determines how much sidewall there is. Take the 305/30/18 for example. The middle number is your sidewall height, the 30 meaning 30 percent of the tire width. In this case, it means the tire's sidewall is approximately 90mm because .30 x 305 = ~90.
Old 09-24-2014, 06:17 AM   #7
Region: Arkansas
Understood. Thank you for the explanation
2012 GT Mods:
JLT 3
MGW Shifter
Brenspeed dyno tune
Old 09-25-2014, 01:11 PM   #8
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
You can definitely get away with a wider tire! For a 10" wide wheel I'd definitely go with a 305. I have 10.5's on the back of my 2011 GT and went with a 315/35/20 and love them! Great traction and perfect height.
Hope this helps! Let us know if we can lend a hand.
-Dan
Old 10-01-2014, 05:30 AM   #9
prettyboy28364's Avatar
wtg guys giving great advice>>>>305 for sure with keeping your 255's up front. I have a 93 Gt vert with 295/35/18 on a 10.5 wheel and I'm also thinking putting 305's on the rear. When I look for wheels and tires I like to google pics or in your case ask questions from members with pics if they have them. Good luck!!!
Mustang Lover 4 Life!!!
prettyboy28364 is offline   Reply With Quote
Wider Tires on oem wheels Greg3 Mustang Wheels & Tires 30 02-08-2015 10:18 AM
Wider TIRES Krisis187 Mustang Wheels & Tires 11 01-24-2013 12:16 PM
Pros and Cons to Wider Rear Tires? tgmeyer Mustang Wheels & Tires 21 09-29-2012 11:54 AM
Wider tires?? 89 Foxloco 1979-1995 Mustang GT 26 05-24-2012 09:18 AM
Retune for wider tires? BossFiveOh 2011-2014 Mustang GT 7 05-02-2012 03:31 PM
03:24 AM
