Widest rear tire I can go - Mustang Evolution
Old 11-04-2014, 10:55 AM   #1
slowstang08's Avatar
I have a 2008 mustang v6 with stock rims and tires and I wanted to go wider in the back.
Size is 215/65/17
Do you think I can go 255?
I also have 2 inch lowering springs if that changes anything
slowstang08 is offline   Reply With Quote
Old 11-06-2014, 05:45 AM   #2
255 should be the VERY MAX you should go.
Lowered car doesn't really matter, However, I'd go with something more low profile, Like 255/40ZR17
Makes the car look better.
RushGotti is offline   Reply With Quote
Old 11-19-2014, 07:33 PM   #3
where can I find a set of the 255/40ZR17?
Old 11-19-2014, 07:53 PM   #4
And shouldn't it be 255/65/7?
Old 11-20-2014, 07:40 AM   #5
LuisBlackGT's Avatar
Just so you know the first number is the width of the tire in mm, the second number is the aspect of the sidewall (percentage of the first number gives you the thickness of the sidewall in mm and the last number is the wheel size.
For example 255/65/17
255mm wide
Sidewall is 65% of 255
17 inch wheel
Hope this helps.
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Widest tire I can go slowstang08 General Mustang Discussion 62 11-06-2014 09:43 AM
Widest rear tire dapope 2011-2014 Mustang GT 17 08-26-2014 11:51 PM
What's the widest tire I can go in the rear BUSHGUTS Mustang Wheels & Tires 6 11-23-2012 01:43 PM
Whats the widest tire you can fit on a stock rim ? SloMoGT 1996-2004 Mustang GT 15 09-10-2012 04:30 PM
Widest tire you can fit on a 2012 GT SkoSter06 2011-2014 Mustang GT 36 12-03-2011 07:42 PM
12:09 AM
