275's and 315's - Mustang Evolution
Old 11-18-2014, 11:09 AM   #1
Socal Stangman's Avatar
275's and 315's
I came across a good deal on a set of 275/40/20 and 313/35/20. I have a 10" wheel out back and a 9" in front, will these tires fit on my wheels? Im more concerned about the rears fitting. Anyone have pics of a 315 in the rear?
Old 11-18-2014, 01:59 PM   #2
Front is fine. I would only put 315s on a 10" if you get a super amazing deal though. 305s are the max I would do on a 10
Old 11-18-2014, 02:09 PM   #3
Thanks
Yeah I was doing a little more research and it seems even a 305 might be pushing it. I probably should stay at 295.
Old 11-18-2014, 02:17 PM   #4
Rapinator126's Avatar
305 is perfectly fine on a 10" been doing it for years, on my cobra, 3v, and on my coyote.
Old 11-18-2014, 02:24 PM   #5
Oh ok. Ill look into this size.
Old 11-18-2014, 02:54 PM   #6
295s and 305s are most common. I'll be running 295s on my 10" soon.
Old 11-18-2014, 03:04 PM   #7
Laquisha's Avatar
275's and 315's
9 255. 10.5 315. Yolo
Old 11-18-2014, 03:09 PM   #8
The only thing I found in a 305 is a drag radial.There isnt much in that size.
Old 11-18-2014, 03:09 PM   #9
Laquisha's Avatar
You obviously didn't look that hard. Lol
Old 11-18-2014, 03:11 PM   #10
There are few tires wider than a 285 that are a "summer" or street tire. The 295s i'm getting are a 200 tread wear tire. Technically they are a street tire, but people pretty much only get them for autocross or open course racing. (BFG Rivals)
Old 11-18-2014, 03:13 PM   #11
Laquisha's Avatar
How much u puttin down rwhp/rwtq, what makes your car so good at auto cross other than coil overs ? What times do u run?
Old 11-18-2014, 03:17 PM   #12
Show me some. I googled 305/35/20...Mainly Nitto 555 DR's.What size are you using?
Old 11-18-2014, 03:18 PM   #13
Its basically a stock 2v. Probably 240hp and 280tq.
What makes it good at autocross is:
Subframe connectors
LCAs
Torque Arm (replaces UCAs)
Panhard Bar
Coilovers (with spring rates for AutoX)
4.10s (short gearing helps keep me in the rpms)
5 point harness with the harness bar
Skill. While there is skill in drag racing, autocross takes a completely different driver. Also don't need much power for Autox, thats why Miatas have a HUGE presence in autocross.
Also my car's alignment has negative camber and toe out, both of which help with turning (too much can hurt straight line).
Old 11-18-2014, 03:19 PM   #14
This is about what I could find that isnt a DR.
http://www.tirerack.com/tires/TireSe...35&diameter=20
I dont want a tire that will only get 20,000 miles or less on it.
Old 11-18-2014, 03:23 PM   #15
Probably won't find much for tires that wide and last longer than 20k.
Old 11-18-2014, 08:52 PM   #16
Raeko's Avatar
315/35/20 nt05r drag radial on a 10 in rim
Raeko is offline   Reply With Quote
Old 11-18-2014, 08:54 PM   #17
Wayyyy too much bulge
Old 11-18-2014, 09:07 PM   #18
Raeko's Avatar
That's what she said lol. Car hooks way better than it did with the 305 nt555r's .
Old 11-18-2014, 09:09 PM   #19
^ Hell yea NT05Rs are the sheeeeet. I break 555r's loose on my bicycle.
Old 11-18-2014, 09:22 PM   #20
That's simply because of better compound. Tires are still too wide for the wheel. You are going to get more wear in the middle than evenly. That means when you launch the full tire isn't even touching.
Old 11-18-2014, 10:12 PM   #21
Raeko's Avatar
All I can say is that they are doing their job and ill post pics later on to determine the wear characteristics. I believe they have full contact considering I run dr's at 20 psi in each tire. Didn't really have traction problems with the prior nittos and they lasted me 2 years. I'm not one of these guys that daily their mustang and all i was looking for was optimum traction in a streetable tire which I just found. For most maybe a sreet tire would suffice but not for what I'm about to do. Nt05r would be a good match if you need some straight line traction and you are making over 450 hp
Trade chrome deep dish bullits 275/315 MachMan1017 General Mustang Discussion 0 01-18-2013 12:32 PM
275/35R19 front & 275/40R19 rear tires combined? M3hunter 2011-2014 Mustang GT 4 07-29-2012 04:15 PM
Tire size 315/35-17 slick Pre-2005 V6 Mustang 13 04-13-2008 10:06 PM
315/35-17 all8280bcc Mustang Wheels & Tires 10 01-30-2007 07:14 PM
18x10/315/30 on an irs cobra? snake99bite Mustang Wheels & Tires 7 05-22-2006 09:22 PM
12:50 PM
