inside and outside - Mustang Evolution
Old 11-25-2014, 09:06 AM   #1
inside and outside
Okay so I curbed my tire and it looks like crap.
The tire is non directional however each side says
"inside" and the other says "outside"
why is this? I was hoping I could have the tire re mounted so the curbed side is inward and not seen.
Hello is offline   Reply With Quote
Old 11-25-2014, 10:08 AM   #2
Strange Mud's Avatar
for traction reasons. I wouldn't.
Old 11-25-2014, 10:36 AM   #3
I thought by it being non directional it would be the same?
Old 11-25-2014, 06:34 PM   #4
Mile high JDF's Avatar
It says inside and outside because the tire was designed to shed water in a certain direction, much like a directional tire
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-25-2014, 07:25 PM   #5
If you want to do it correctly, have both of the tires on the same axle turned around on their rims and then put the bad tire and wheel on the opposite side of the car where the damaged sidewall will be on the inside and the tire will be rotating in the correct direction.
Old 11-25-2014, 07:53 PM   #6
Forget what I just said about re-mounting your tires Hello... They're asymmetrical. Your car will handle like a turd if you do it and wet traction will also suffer.
Try some Tire Shine!
An Inside Look at Steeda - Video Inside tj@steeda General Mustang Discussion 2 06-24-2014 05:58 PM
Strong oder of gas inside and outside of car GTIFIFY General Car Discussion 1 08-03-2013 11:39 PM
Nice and clean on the outside... Thegabrielles 2011-2014 Mustang GT 21 01-21-2011 05:55 PM
Inside and outside vids of my car Testicleez The Bar 14 03-05-2004 11:16 PM
riced out Stang outside my window... Stang01 The Bar 8 07-18-2003 10:13 PM
11:57 PM
