Wear on inside edges of front tires - Mustang Evolution
Old 12-22-2014, 02:08 PM   #1
iguanaman3's Avatar
I bought my 2012 v6 pony pkg. premium used with 27,000 miles. When I looked at the tires they were inflated to 50 lbs. and had uneven wear in the center tread of course. I fixed the pressures and rotated them and found both fronts also had a lot of wear on the inside edges. I don't believe they were ever rotated before this. My question is about the wear on the inside fronts. Is this normal front wheel wear or could the alignment be off? I checked and they are stock springs. Is there even any toe out adjustment on the stock suspension? I am getting new tires soon and would like to take care of any adjustments that would cause premature wear.
Thanks.
iguanaman3 is offline   Reply With Quote
Old 12-22-2014, 03:26 PM   #2
WJBertrand's Avatar
Yes, I would say there's an out of alignment condition. You're either running too much negative camber or there's excess toe out. Either situation can cause that inside edge to wear too fast. The toe out condition can also affect fuel mileage slightly.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 12-31-2014, 05:20 PM   #3
If they were never rotated this isn't uncommon. If the car drives well just leave it. It amazes me how many think the Max Pressure listed on the sidewall is the proper pressure for the car. When I bought my 03 GT from my brother he told me he always kept the tires at the proper pressure of 45 PSI. When I showed him the door jamb (35 PSI) and told him the car never rode, cornered, or accelerated like it should have he went back to the tire (not even OEM) and said "no, it says Max 45PSI and thats what I did. You can't fix stupid. Glad you know better.
chitownpete is offline   Reply With Quote
Old 12-31-2014, 09:28 PM   #4
Bear376's Avatar
The S197 Mustangs do not have full alignment capability. It is routine to find them with camber issues. I just replaced my front tires because of the same issue, and other members of my club have said they had the same problem. Since I was getting ready to upgrade my struts, I bought the GT500 strut mounts and Eibach camber adjustment bolts. The bolts are only $35, and you should have the front alignment done at the same time you install them. The bolts should solve the camber issue.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 01-02-2015, 01:13 PM   #5
c_rizzle's Avatar
It probably WAS lowered before with stock springs put back on before trading it in.
My stock springs & axlebacks are sitting in a box ready to be reinstalled for when I trade my car in, to make it look like it was mostly stock.
c_rizzle is offline   Reply With Quote
Old 01-02-2015, 04:13 PM   #6
iguanaman3's Avatar
I guess it is possible it was lowered because it has PP struts, shocks and sway bars that were not available on automatics in 2012. But the wear seems to be still happening on the rotated tires. I am beginning to believe it is toe out that is causing it because It only effects the inside edge and the car is a bit "darty" but otherwise tracks straight as an arrow.
Old 01-02-2015, 08:58 PM   #7
satin06silver's Avatar
If you have the coin just go ahead and buy the plates. The bolts will wear out eventually, plus they tend to get loose, but thats just my .02 I got the plates because I got tired of messing with the bolts.
“I don’t lose any sleep at night over the potential for failure. I cannot even spell the word.”
Gen. James "Mad Dog" Mattis USMC (Ret.)
satin06silver is offline   Reply With Quote
Old 01-03-2015, 01:28 AM   #8
Plates are infinitely better than bolts
Old 01-03-2015, 10:18 PM   #9
Panther140's Avatar
make dat **** hella flush yo. Hellaflush+Vtecyo = #jdmAs****
Panther140 is offline   Reply With Quote
Inside wear on front tires 03fastblack 1996-2004 Mustang GT 9 10-15-2012 09:58 AM
Boss 302 grille in with Race Red edges gtstyles2 2011-2014 Mustang GT 2 11-19-2011 08:07 AM
Unusual wear on inside wall of front tires Hm3grant 1996-2004 Mustang GT 18 07-24-2011 09:15 PM
Excessive inside rear tire wear CakeOrDeath? Pre-2005 V6 Mustang 14 12-14-2010 12:39 PM
Might have a lowering kit for edges soon!! sonic04edge The Bar 62 01-31-2005 02:06 PM
07:42 AM
