Wheel sticks out - Mustang Evolution
Old 02-10-2015, 04:59 PM   #1
Wheel sticks out
I have some 295/35ZR20s on my 2014 stang v6 and i noticed one tire sticks out more than the other. Anyone knows what this could be?Click image for larger version
Name:	ImageUploadedByMustang Evolution1423612750.277379.jpg
ID:	175160Click image for larger version
Name:	ImageUploadedByMustang Evolution1423612768.945515.jpg
efrain is offline   Reply With Quote
Old 02-10-2015, 08:04 PM   #2
LuisBlackGT's Avatar
Is your car lowered? If so, an adjustable panhard bar would fix this
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 02-10-2015, 08:17 PM   #3
Not at all, its stock you couls say just different wheels
Old 02-10-2015, 09:20 PM   #4
Devil Strider's Avatar
Mines does it a little now because I have wide rear tires.
Devil Strider is offline   Reply With Quote
Old 02-10-2015, 09:23 PM   #5
WhiteCali5oh's Avatar
Region: West Virgina
I wish mine only stuck out that much. Mine go probably 1/2 inch past the fender lips
WhiteCali5oh is offline   Reply With Quote
Old 02-10-2015, 09:23 PM   #6
natestang07's Avatar
Originally Posted by efrain View Post
I have some 295/35ZR20s on my 2014 stang v6 and i noticed one tire sticks out more than the other. Anyone knows what this could be?Attachment 175160Attachment 175161
Just wide tires
Old 02-10-2015, 09:27 PM   #7
Name:	ImageUploadedByMustang Evolution1423628799.375418.jpg
Here is how mine stick out. I don't have a good shot from straight in but you can see how far they're out lol
Old 02-11-2015, 07:01 AM   #8
Yea but one sticks out more the the other
Old 02-11-2015, 07:40 AM   #9
It doesnt look like it in the pictures but they stick out about half inch aswell
Old 02-12-2015, 04:29 PM   #10
Socal Stangman's Avatar
I suggest an adjustable panhard bar.
Old 02-13-2015, 05:05 PM   #11
NacsMXer's Avatar
It's normal; it's how these cars come from the factory. I noticed the same thing after I installed wider wheels/tires on my 2014. You and I just never noticed this before with the stock wheels since they are tucked so far into the wheel wells. Wider aftermarket wheels and tires simply accentuate what was already going on.
Like these guys said above, get an adjustable panhard bar to fix it. You will be able to center the axle under the car that way. It won't hurt anything if you leave it as is though either.
NacsMXer is offline   Reply With Quote
Old 02-13-2015, 05:09 PM   #12
Thanks! I will be getting a panhard bar with my lowering springs
Old 02-13-2015, 05:15 PM   #13
Would just a PH bar and springs be good enough for a 1 inch drop? Wouldn't you need more?
Old 02-13-2015, 05:36 PM   #14
For a 1 inch it should be since you wont be lowering it much
Old 02-13-2015, 05:39 PM   #15
Ok, I didn't know if the stock Struts and shocks should be replaced as well.
Old 02-13-2015, 05:40 PM   #16
Is a 1 inch drop what you will do?
Old 02-13-2015, 05:42 PM   #17
Yeah.
Old 02-13-2015, 06:08 PM   #18
Yeah.
Oh ok yea it should be pretty simple for a 1 inch the struts and all that is extra, and mainly needed for a low ride
Old 02-13-2015, 08:11 PM   #19
Would just the springs help any of the body roll, nose dive, etc? I wouldn't think so. Either way, I can just purchase those later.
Old 02-13-2015, 08:37 PM   #20
Oh yeah dude. I lowered mine 1.5 with only springs and helped the brake dive. Squat on acceleration. Body roll. All was GREATLY improved!!
Old 02-13-2015, 08:50 PM   #21
Ok then. I want to get the FRPP P springs, but it says I need the GT500 strut mounts. Couldn't I just install the springs, and the PH bar and be fine?
I'd purchase the mounts and new shocks and struts eventually.
Old 02-13-2015, 08:54 PM   #22
Wheel sticks out
Idk about that. I have the eibach pro kit man. I changed those, BMR double adjustable panhard bar, bmr lower control arms, bmr relocation brackets, bmr upper
Control arms, bmr upper mounting bracket and eibach camber bolts. If you want to use a strut for a 05-2010 mustang, you have to change the strut mounts in order to do that. That is my next mod. I don't see why u HAVE to change the strut mounts if you're not doing what I stated above? Maybe it's something to do with the frpp springs. Who knows. Maybe someone else will chime in.
Old 02-13-2015, 08:58 PM   #23
I am fairly certain it's just FRPP wanting to get more money out of the person.
Old 02-13-2015, 09:01 PM   #24
Probably so! A lot of guys say the SR SPRINGS are good too. And steeda so you should check those out as well man!
Old 02-13-2015, 09:06 PM   #25
SR=Shi*ty Replacements. I'll check out steeda as well. I can get the FRPP springs for about 170 though.
Old 02-13-2015, 09:08 PM   #26
I've never heard someone call them that lol. I mean if you're like me and won't be road coursing or auto crossing it probably won't make a difference.
Old 02-13-2015, 09:10 PM   #27
True. I'll probably go with FRPP, Steeda, or BMR.
Old 02-13-2015, 09:13 PM   #28
Can't go wrong there!!
Old 02-15-2015, 07:59 PM   #29
I like FRPP the best for your buck
str8boostin is offline   Reply With Quote
Old 02-15-2015, 08:01 PM   #30
Exactly.
Old 04-12-2015, 01:58 PM   #31
Gumbus's Avatar
my wheels are off centered. i guess when they installed the panhard bar they forgot what adjustable meant. great.
Gumbus is offline   Reply With Quote
Old 04-13-2015, 05:27 PM   #32
Diehard's Avatar
OH! you want adjustment, that's at additional cost. LOL
TR3650 shifter sticks sikstang03gt 1996-2004 Mustang GT 7 02-20-2015 03:27 AM
Clutch pedal sticks at redline JR4288 2011-2014 V6 Mustang 12 12-09-2014 05:22 PM
Sticks n Stones Plague 2011-2014 V6 Mustang 8 04-04-2012 04:46 AM
What Happens When you light 30,000 match sticks at once? Brent Pictures and Videos 10 06-26-2007 12:17 PM
Air and Sticks for Sale drummerstang98 The Bar 1 09-07-2004 11:33 PM
04:34 AM
