HELP!!! - Mustang Evolution
Old 03-07-2015, 10:46 AM   #1
HELP!!!
I need help.
I currently put some AMRs on my 2001 GT. They came off a 2012 GT. They fit and everything but when I'm driving I get a green light popping up on the dashboard having to do with the traction. When the light pops up I can't give the car anymore gas anymore. What can be the problem?
Up front I have 19 x 8s AMRs with 245/45/19 tires and on the back I have 19 x 10s with 275/35/19 tires. When I put back my 17 x 9 Cobra Rs on the front with 245/45/17 tires I don't get the problem anymore...what could the problem be. I know it has to do with the from AMR wheels
borrayo7427 is offline   Reply With Quote
Old 03-07-2015, 11:12 AM   #2
oxford5pointoh's Avatar
That's the traction control/ abs I believe. I don't know that it has to do with the wheels as much as it may just have a faulty sensor. I would check and make sure all the wires are out of the way of the new rims, and check the sensors and clean them up.
Old 03-09-2015, 08:56 AM   #3
LuisBlackGT's Avatar
The amr wheels and tire may be too tall in the front considering they are 2 inches taller then your old ones
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 03-09-2015, 09:07 AM   #4
fenixignition's Avatar
if you have 245/45/19s on a car that normally take 245/45/17, then your wheels are moving at a different speed than they are supposed to. so the wheel speed sensors are probably confused as all hell thinking you have awful traction and trying to save your life. (and car)
2002 GT 5sp. 16x,xxx miles
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
03:57 AM
