255/40 vs 275/35 Nitto NT05 - Mustang Evolution
Old 05-14-2015, 06:07 AM   #1
ninjamatic's Avatar
Want better stick for my Track Pack GT. Mods are CAI, Catback, Tune, springs, upper and lowers, panhard, relos, MGW
I take mine to the strip maybe once per year. Might do a CJ or Boss eventually but with the NT05 I mostly do street driving and put 3.5k on the ODO per year so she only sees nice weather.
Reason I'm asking is because I have the 19" Brembo rims OE. With the 35 I would lose about half inch on diameter.
I know jack about wheel setups
Will the small loss in dia effect me much going with the 275 or keep the slightly taller 40 on a 255. Needs more stick without heating them up in case I need it.
Thoughts?
Sent from my Nexus 6 using Mustang Evolution mobile app
Video Game Developer | PS4, PC
2014 GT Premium Track Pack | Sterling Gray
ninjamatic is offline   Reply With Quote
Old 05-14-2015, 06:54 AM   #2
whitboy82's Avatar
If I remember correctly, if you start to dip under the stock diameter 27", then it begins to effect your gear ratio. So if you have 3.73s and you go to a 275/35-19 from a 255/40-19 your ratio will drop from 3.73 to 3.67...but that's about the only negative.
You could go with a 275/40-19 and that would put you a little over 27" diameter, and that would also raise your gear ratio to 3.82. A lot of people like the look of the slightly larger tires on the mustang for looks and better grip from a larger sidewall.
2014 Sterling Silver Mustang GT 6M Track Pack
C&L CAI, Lethal ORX/OTAs, FM Outlaws, SCT V4 AED Tuned, SR Springs, SR LCAs, BMR Panhard, Roush Lip, MMD Duckbill, CDC Grill, Boss Rear Valance, 20x9/20x10.5 Concept One CS-6
whitboy82 is offline   Reply With Quote
Old 05-14-2015, 07:54 AM   #3
Diehard's Avatar
I think you have the effects of smaller dia tires backwards. Smaller dia increases the gear ratio. Double check your source.
Old 05-14-2015, 08:13 AM   #4
whitboy82's Avatar
Yeah, looks like I had it backwards
Old 05-14-2015, 08:47 AM   #5
ninjamatic's Avatar
Hmmm. Nitto doesn't make a 275/40/19 for the NT05.
Would there be much of a hook difference between 255/275 seeing that they are drag radials?
Old 05-14-2015, 11:35 AM   #6
tezz's Avatar
I run the 275/40/19 BFG Sport Comp 2's on my GT with 3.73 gears, 9.5 inch SVT rims and really like them on the track. Right now those are just in the back - the fronts are 255's, which I plan on replacing with 275's to square it up when I wear them out.
2013 Ingot GT, 6M, FRAA Susp, GT500 Axle Backs/Wheels/Spoiler, Baer/Shelby brakes, Recaros, Trac-Cal, etc.
tezz is offline   Reply With Quote
Old 05-14-2015, 11:39 AM   #7
Rapinator126's Avatar
The nt05 is not a drag radial.
The nt05r is the drag radial.
Old 05-14-2015, 12:05 PM   #8
tezz's Avatar
You're right - I forgot he said 'strip' - my BFG's aren't drag radials either.
Old 05-15-2015, 04:20 AM   #9
ninjamatic's Avatar
My bad I did mean the r
Are the Nt05 a good tire 1st stang Mustang Wheels & Tires 15 08-22-2013 07:37 AM
275/35R19 front & 275/40R19 rear tires combined? M3hunter 2011-2014 Mustang GT 4 07-29-2012 04:15 PM
Nitto nt05 2011 5.0 BossFiveOh 2011-2014 Mustang GT 1 04-27-2012 07:19 PM
Nitto NT05 and NT05Rs installed + New wheels! Napoleon85 Pictures and Videos 11 04-10-2012 09:49 AM
11:06 PM
