New Wheel fitment - Mustang Evolution
Old 06-13-2015, 05:05 PM   #1
Smoked50's Avatar
New Wheel fitment
I have decided to go with the Shelby Super Snake Black wheels from American Muscle. They are 20x10R 37mm O/S and 20x9F 24 mm O/S with 255-35-20 and 295-35-20 Nitto Invos.. Any thoughts on any possible issues with this setup on a 2015 GT 1" lowered? Tires have about a 7/8 " difference in dia. / height. Should that cause any problems with the ABS system?
There is a car on their website with this setup and it looks like it works OK.. I don't want a wheel to stick out though.
Smoked50 is offline   Reply With Quote
Old 06-14-2015, 01:55 PM   #2
Mean14's Avatar
I know the 15s are a different platform than my 14, but I ended up going with a similar setup (20x8.5 255 35 20 up front and 20x10 285 35 20 in the rear)
I also recently lowered her on some eibach sportlines which drop 1.3 up front and 1.7 on rear. I was on the highway doing 80 hitting some decent size bumps to test out the waters, and there were no problems at all. The wheel won't stick out too badly, it will be pretty flush with the fenders though. It'll look good IMO
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-14-2015, 05:10 PM   #3
Smoked50's Avatar
What are your offsets
Old 06-14-2015, 08:01 PM   #4
Mean14's Avatar
Fronts are +30mm and rear is +48mm
Old 06-15-2015, 10:49 AM   #5
Socal Stangman's Avatar
I'm thinking you'll be fine with this setup. I ran a 275/35/20 with a positive 18 with no issue.
Old 06-15-2015, 02:31 PM   #6
Smoked50's Avatar
After checking weights I want to go with the CDC Outlaws in a 20x10R 41mm, and 20x9F 35mm Nitto Envo's 295-35-20 and 275-35-20. Trying to locate wheels now. They are pricey but light. I am told this will tuck in good on a 15 lowered 1"..
Any thoughts?
Old 06-15-2015, 04:54 PM   #7
Any thoughts?
I have a 14 but I'm guessing Ford didn't change the wheel and tire setup much. The new set you're talking about should fit a little better than the first set.
Old 06-15-2015, 08:18 PM   #8
Diehard's Avatar
I notice the stock 2015 GT's have reduced the space between the tires and the fenders quite a bit. (Haven't noticed the 4 and the V6.) Also, with the independent rear suspension components of the 2015, I doubt you can rely on comparing it to the 14's for clearance issues.
Old 06-16-2015, 05:26 AM   #9
Smoked50's Avatar
I talked with one of the vendors and they have a shop car running this size wheel, same offset with 305's and they fit perfect they said.
Wheel and Tire fitment rayrivas Mustang Wheels & Tires 5 11-07-2013 12:49 PM
Wheel fitment 2010-2013 ARfirefighter Mustang Wheels & Tires 8 11-21-2012 09:32 PM
wheel fitment. robert3188 1979-1995 Mustang GT 9 12-03-2011 09:25 PM
17x10.5 wheel fitment question Evil J Mustang Wheels & Tires 4 10-30-2009 07:19 AM
69 tire and wheel fitment Indymustang Classic Mustangs 1 09-12-2006 08:25 AM
03:20 PM
