Wheel size - Mustang Evolution
Old 06-17-2015, 08:55 AM   #1
Wheel size
Hey I'm about to buy some velgen vmb5 for my 2014 mustang gt and I'm on h&r lowering springs I was thinking if i should go with 20x9 in the front and 20x10.5 in the rears or 19x9 and 19x10 the wheel offset is +45mm I jus don't want the wheels to rub thanks
karanvirgill5.0 is offline   Reply With Quote
Old 06-17-2015, 11:36 AM   #2
Mean14's Avatar
I have 20x8.5s 255/35 up front with 30mm offset and 20x10s 285/35 in rear with 48mm offset. Lowered on Eibach Sportlines. Which is a 1.3" front and 1.7" rear drop on my v6. I haven't had any problems. I was on the highway doing 80 hitting some good size dips/bumps to test the waters, and did not bottom out or rub at all.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-17-2015, 11:33 PM   #3
My springs lower me about 1.7 in the front and 2.4 in the rear my car is lower than yours 😅 and I'm think about goin 305s rear tires and 255 or 85 in the fronts
Old 06-18-2015, 06:07 AM   #4
Mean14's Avatar
Are you changing shocks/struts too?
Old 06-18-2015, 11:28 PM   #5
no going to keep stock shocks and struts. Just adding H&R super sport lowering springs, bmr control arms, and bmr adjustable panhard bar.
Old 06-19-2015, 01:54 PM   #6
Mean14's Avatar
You'll probably going to need to change shocks/struts with such a significant drop within the next year or so. The oem shocks/struts will wear out a lot faster.
Old 06-26-2015, 11:43 AM   #7
Socal Stangman's Avatar
You should have no issues as long as you use the +45 in the rear. You might be able to get away with a +40 as well, depending on what size tire you need. Fronts +30 to +35 is good, but you could also go as much as a +25 in the front.
Old 06-27-2015, 10:05 PM   #8
Sakol's Avatar
Anyone tried fender rolling when going lower than +25?
Sakol is offline   Reply With Quote
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
97 v6 Wheel Size Kiljosh Mustang Wheels & Tires 17 11-09-2004 11:26 PM
NEED HELP with Wheel size Linkan Mustang Wheels & Tires 6 04-25-2004 10:00 AM
12:40 PM
