255/35/20 tire - Mustang Evolution
Old 11-19-2015, 12:49 PM   #1
Cooolbreeez's Avatar
255/35/20 tire
What do you keep the tire pressure at for every day driving? Same as stock?
Cooolbreeez is offline   Reply With Quote
Old 11-19-2015, 01:07 PM   #2
Sterlingbeast5.0's Avatar
I keep it right about 38
Old 11-19-2015, 03:07 PM   #3
Thanks sterling.
Old 11-19-2015, 05:59 PM   #4
Commercial Member
au01st's Avatar
36 here. Still figuring out what I like. Backed them down from 40 the shop aired them to.
Sent from my #racecar
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 11-19-2015, 11:47 PM   #5
Mine came with 50 in them, dropped them to 38, might try 35. When I backed ithe car out of the garage to turn it around and do the other side it was so stiff. Felt way better when I let the air out.
Old 11-28-2015, 03:06 PM   #6
Coyote2820's Avatar
Does anyone have a pic of their 255/35r20s or 255/40r20s? I'm trying to decide what to throw on the fronts that will compliment the 275/40r20s on the back.
2014 5.0 GT Premium - Active Duty
2013 5.0 GT - Retired
2003 GT - Retired
Coyote2820 is offline   Reply With Quote
Old 11-28-2015, 03:18 PM   #7
Hope this helps. I'll get a closer shot of the tire from the side if you need it.
Old 11-30-2015, 09:06 AM   #8
Coyote2820's Avatar
It does, they look good and the wheels do too. I appreciate it, thanks partner.
2003 GT - Retired
Old 01-16-2016, 09:08 AM   #9
36-38
madmikeks is offline   Reply With Quote
Old 01-16-2016, 10:11 AM   #10
oxfordwhite's Avatar
255/45-18's we run 35.
oxfordwhite is offline   Reply With Quote
Old 01-20-2016, 11:30 AM   #11
ascottg96's Avatar
Id do 32-35psi. Maybe even a little higher if you really want. I wouldn't go much over 40psi if you don't have to. Some valve stems cant handle 40+ psi(unless you have tpms or a high pressure stem)
ascottg96 is offline   Reply With Quote
255/40-19 Micky Thompson Tire Deal Rufeo Mustang Wheels & Tires 5 02-03-2015 09:09 PM
235/50 tire on 255/45 wheel? binly Mustang Wheels & Tires 6 05-28-2014 10:41 AM
Will a 255/45r17 tire fit on my stock 2007 mustang rims ? beverley86 Mustang Wheels & Tires 1 08-21-2009 03:26 AM
04:58 PM
