big problem help me - Mustang Evolution
Old 11-24-2015, 07:46 AM   #1
Region: Asia
big problem help me
Hi my friends
Iam from dubai and my language is not good put i will try to explain my problem
I have mustang 2011 gt with 8 inch wheels from factory.
I fit 275/40/18 on 8 inch in back tires and here start the problems.
When i drive 100 or 120 or any speed i feel the car move left and wright quickly i sure the move in back only not front because all angels in front i was check its good
I replace 275/40/18 to 245/45/18 and i feel the car not stability in back move right and left whats the problem in back realy iam very tired please help me .
mr.danger22 is offline   Reply With Quote
Old 11-24-2015, 09:53 PM   #2
BigJay's Avatar
Start with checking rear panhard bar to make sure the bar and its mounting bracket has not come loose.
BigJay is offline   Reply With Quote
Old 11-24-2015, 11:44 PM   #3
Region: Asia
You can tell me whats the panhard bar ? Another name for this ?.
Old 11-25-2015, 12:01 AM   #4
oxford5pointoh's Avatar
The "panhard bar" is a bar that connects to the chassis of the car on the passenger side and the rear differential on the drivers side.
I don't think this is your problem though, but I would make sure that you check all your bolts and make sure they are tight. Especially if you have lowered the car or done any suspension work. You want to torque the bolts that hold the rear end in place to 150 foot pounds using a torque wrench.
Now it sounds like you have already identified your problem. The 8" wheel is just not going to cut it if you want to have a decent amount of rubber on the road. Why not upgrade to a 10" or 11" rear wheel and run a 285 or 305?
Old 11-25-2015, 12:56 AM   #5
Region: Asia
I check now panhard bar all bolts is tight good about it .
Oxford 5 pointoh now i know my mistake i must increase to 9 or 10 inches.
My car is only 30000 mile i dont add suspention or lowerd realy i think the problem in rear tires because its from china ^sonar^ realy iam boring
Old 11-25-2015, 02:55 AM   #6
audioAl's Avatar
Find a known "name brand" tire to buy. At least 9" rims, that should help a lot.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 11-25-2015, 09:37 AM   #7
Region: Asia
Thank you all about a good information.
Old 11-25-2015, 05:47 PM   #8
RCrumb's Avatar
I think before you go and replace the tires have a full alignment done on the car to make sure everything is strait. Then as audioAI suggest buy a good set of name brand tires, they don't have to be expensive, just a good reputable brand. Don't go crazy wide on the fronts either, suggest 8.5" wide, as wider tires on the front can sometimes give the impression of pulling. Rear, go as wide as you like. Best of luck.
RCrumb is offline   Reply With Quote
BIG PROBLEM ON PROCHARGED V6 - help grom80 2011-2014 V6 Mustang 29 03-30-2015 09:03 PM
Big Problem, need help! EMERGENCY! Project Pony Pre-2005 V6 Mustang 22 02-05-2013 12:02 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Stiff gear shift. Small or big problem?? ecash General Mustang Discussion 0 03-17-2009 03:48 PM
Big Problem Guys- Engine shuts down! DMAC Pre-2005 V6 Mustang 7 12-03-2007 10:29 AM
12:12 PM
