Bought some used fr500 s for my stang, concerns. - Mustang Evolution
Old 04-13-2016, 01:51 PM   #1
FortyBrandon's Avatar
So I bought me a set of 7 black fr500 wheels. 4 comes with tires
2 are 18x10 with decent tires but there's some camber wear on sides, are these useable?
2 are 18x9 with offset 22 but one wheel is cracked. I won't use that one.
Other 3 are 18x9 with offset of 65. Only one wheel is useable right now.
If I use the tires than I will only need one 275 35 18 for me to install wheels.
Can I use the same 18x9 up front but one with 22 offset and other 65 or will that damage car?
Sent from my LG-H900 using Mustang Evolution mobile app
ID:	199681   Click image for larger version
FortyBrandon is offline   Reply With Quote
Old 04-13-2016, 05:37 PM   #2
Mile high JDF's Avatar
I wouldn't recommend doing that. The 22 offset wheel will sit close to flush while the other will be sunken in quite a lot. It could quite possibly cause the car to pull while driving as well.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-15-2016, 09:09 AM   #3
Thanks So you think these two wheels could be fixed to use?
ID:	199784   Click image for larger version
Old 04-15-2016, 01:25 PM   #4
Yah a wheel shop should be able to fix at least one of those.
Old 04-16-2016, 11:23 AM   #5
olerodder's Avatar
Region: Oregon
Yes a wheel repair facility can repair them both....one is pretty minor the other may require welding and machining....probably $100 to $150 each. Since I am on the West Coast I really can't comment on the $$$. For $300 to $350 you could have them widened to 10" or 11" wide....just a thought.
Old 04-19-2016, 11:46 AM   #6
He could buy two new 18x10 reps for that price...
I do agree that a decent shop could repair the damage done to both wheels.
Stock Automatic Driveline Concerns DtrMustang 2005-2010 Mustang GT 7 08-17-2013 08:02 PM
Tune before driveshaft swap concerns. Redsix 2011-2014 V6 Mustang 29 06-10-2013 09:08 PM
V6 Lowering questions or concerns!!! RaysV6 Pre-2005 V6 Mustang 8 06-03-2012 09:22 PM
EGR delete concerns sledgehammer Pre-2005 V6 Mustang 14 01-07-2010 11:52 PM
Idle concerns 98GreenStallion Pre-2005 V6 Mustang 22 03-14-2005 09:40 AM
09:50 AM
