Negative camber! Not good!!! - Mustang Evolution
Old 04-13-2016, 10:26 PM   #1
jj4life24's Avatar
Year later after lowering.
Name:	ImageUploadedByMustang Evolution1460607970.659668.jpg
jj4life24 is offline   Reply With Quote
Old 04-14-2016, 12:19 AM   #2
Revvv's Avatar
An alignment would have been helpful.
Old 04-14-2016, 12:40 AM   #3
jj4life24's Avatar
Yea and some camber bolts
Old 04-14-2016, 06:56 AM   #4
noldevin's Avatar
Camber bolts aren't needed. You can run 1-2 degrees of negative camber without seeing too much wear, as long as your alignment is good and toe is near 0.
noldevin is offline   Reply With Quote
Old 04-14-2016, 07:50 AM   #5
jj4life24's Avatar
Do you know what they do to adjust the camber
Old 04-14-2016, 08:01 AM   #6
noldevin's Avatar
They move the strut at the top of the mount. If they can't get it into range you need castor/camber plates. Camber bolts are dangerous, they are much smaller than the stock bolts and are known to shear or break.
Your wear pattern looks way worse than it should for a couple degrees of camber so either your have like 3-4 degrees of camber, or I'm guessing toe is too much. They should be able to fix toe even without camber bolts or plates.
Old 04-14-2016, 08:15 AM   #7
jj4life24's Avatar
Is $150 too much for alignment? they asked me for the year and model and if I was lowered with aftermarket wheels
Old 04-14-2016, 08:37 AM   #8
Revvv's Avatar
Depending on circumstances and shops, that price is likely average. It is a little on the high side in my opinion, but not unreasonable.
The wheel and tire shop I use typically charges about $65 for a front end alignment.
Old 04-14-2016, 08:40 AM   #9
Revvv's Avatar
I just noticed that you're in Cali. The price you have is likely the average there. Prices for everything on the left coast are a bit more inflated than they are in the South East.
Old 04-14-2016, 03:52 PM   #10
jj4life24's Avatar
Name:	ImageUploadedByMustang Evolution1460670730.732893.jpg
Old 04-14-2016, 03:56 PM   #11
jj4life24's Avatar
Name:	ImageUploadedByMustang Evolution1460670982.730293.jpg
Old 04-14-2016, 04:17 PM   #12
Revvv's Avatar
The red numbers measured before adjustment are outside of the accepted range. It may not look like a lot, but it is just enough to cause the tires to be pushed down the road rather than roll as they should.
Pushing and dragging down the road are exaggerated terms, but it is a small visual of what is happening. There is a little bit of resistance in the rolling.
With an alignment all should be normal.
Old 04-14-2016, 05:06 PM   #13
DiESeven's Avatar
I've been too lazy to get an alignment since lowering... All four wheels look like this from rotating them, giving them all a turn at being camber life in the front lol.
Name:	ImageUploadedByMustang Evolution1460675116.273065.jpg
Instagram: @v6beast
Old 04-14-2016, 05:35 PM   #14
jj4life24's Avatar
So what part in the paper made my wheels bald on the inside
Old 04-14-2016, 05:46 PM   #15
jj4life24's Avatar
Attachment 199748
Instagram: @v6beast
Mine were worse lol
Old 04-14-2016, 05:52 PM   #16
jj4life24's Avatar
Damn
Old 04-14-2016, 06:02 PM   #17
Revvv's Avatar
I don't think the paper itself had an impact on your alignment. I've never seen a standard sheet of office paper have an influence on a car's alignment.
Sorry, I couldn't resist.
The toe was out a few hundredths of an inch.
Old 04-14-2016, 06:07 PM   #18
jj4life24's Avatar
Lmao I could of sold some to AM
Old 04-14-2016, 07:57 PM   #19
Diehard's Avatar
Believe what noldevin said about extreme inner edge wear is primarily toe adjustment.
And as many probably know, Ford does not recommend camber adjustment except as outlined in their service manual, which is by slotting the bottom hole of the strut and using their "service repair kit (3C396)".
Ford Service Manuals - GENERAL PROCEDURES = Covers the procedure to grind out bottom hole in struts.
Old 04-18-2016, 08:09 AM   #20
noldevin's Avatar
It was toe just like I said. 0.4 is quite a lot of toe, I probably would have asked if they could get it any lower than .18 but it should be much better now.
Negative effects Ntbruncie 2011-2014 V6 Mustang 24 02-15-2014 08:36 AM
How much negative camber do i need? OzzyLiriano 2011-2014 Mustang GT 1 02-28-2013 06:49 AM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Negative Camber Eating my Tires djmaincheese Pre-2005 V6 Mustang 11 07-01-2006 01:11 PM
04:50 AM
