Need help with wheel size with my mustang? - Mustang Evolution
Old 07-14-2016, 01:50 PM   #1
I found these 18inch set of wheels with 18x9 and 18x10 and everything seems to be good except for the offset they wheels offset is 22 but the offset reccomend for my mustang is offset of 35-40 so if i were to buy the wheels with 22 offset would that be a problem????
Mendoza1213 is offline   Reply With Quote
Old 07-15-2016, 05:56 PM   #2
noldevin's Avatar
Yes. That probably won't clear brakes without a huge spacer. Get wheels with the correct offset
noldevin is offline   Reply With Quote
Old 07-15-2016, 08:11 PM   #3
Diehard's Avatar
Actually a lesser offset pushes the wheel/tire further outboard, not inboard. Also, it's more the design of the wheel spokes that clears or don't clear big brake calipers. But I don't think we are talking big brakes.
The 22mm vs. say a 35mm offset only amounts to the wheel assembly moving outbound by 1/2". Chances are you'd just be looking at the wheel possibly sticking out from the fender a bit.
Take a look at this site to get a better idea of what happens when sizes change. Typically it's used to check for clearance compared to an existing setup.
Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
Moving the wheel outboard by a 1/2" by way of the offset would have a similar load effect on the wheel bearings as would putting in 1/2" spacers. Some don't recommend that much for the front wheels.
Old 07-15-2016, 08:34 PM   #4
noldevin's Avatar
Right. My bad wasn't paying attention. However I still think 22 offset will fit like crap and quite possibly rub the fender. I'm not sure what year mustang OP has, but on a 10-14 the factory 9" wheels are typically around 42 offset. The 20mm difference is a little more than 3/4 of an inch.
Old 07-15-2016, 08:44 PM   #5
Diehard's Avatar
Agree...I certainty would want to look into that very closely before getting 22mm offsets.
Old 07-29-2016, 08:32 AM   #6
stang3.7's Avatar
Name:	ImageUploadedByMustang Evolution1469802506.868676.jpg
This is 30. The difference in 10 mm is 3/8"
stang3.7 is offline   Reply With Quote
Old 07-29-2016, 08:32 AM   #7
stang3.7's Avatar
30mm offset front
Need help choosing wheel size. I Do not know which ones to pick? FortyBrandon Mustang Wheels & Tires 4 01-27-2014 07:34 AM
Need help deciding wheel size rebeltx Mustang Wheels & Tires 8 11-05-2012 09:04 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
HELP!!! Wheel Size Question cullop51 Mustang Wheels & Tires 4 03-10-2006 11:35 PM
NEED HELP with Wheel size Linkan Mustang Wheels & Tires 6 04-25-2004 10:00 AM
07:19 PM
