Need tire advice, need to be able to hook! - Mustang Evolution
Old 08-11-2016, 09:50 PM   #1
LaserRed99's Avatar
Next week I should be close to 600 rwhp, so I'm going to need some new rubber in the back. I'm running regular NT555 right now, and they already spin all day even at 450 rwhp until I hit third.
Check out 9:20 in this vid... yeah.
https://youtu.be/-O5F_d2qpG8?t=9m20s
I'm mainly thinking about either NT555R, NT05R, Proxes R888, or M/T ET Streets. Any other suggestions? I will be putting 8-10k miles on per year so tread wear needs to be decent-ish. I don't mind buying tires twice a year, but any more than that is too much. I also don't need to dead hook in first on the street or anything, if they can hook from a 15-20 roll that is fine.
Opinions?
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 08-12-2016, 07:30 AM   #2
R888 will do ok, just very pricey. 555R would probably be your best bet for what you are looking for. In my experience the ET Street requires decent heat to hook.
Sent from my XT1045 using Tapatalk
Old 08-12-2016, 09:15 AM   #3
ET Streets will hook decent but tread life blows.
I had 555R's on the Shelby and they weren't that great at 540rwhp. Still spun in 1st and 2nd, but then again they were half used up already. I have heard they last better than the others you listed.
I'd guess your best bet would be the NT555R's for an all around tire. Maybe NT05's. Not sure how much I'd trust those in wet conditions though.
At that power level, it's tough to get a tire that will do EVERYTHING, so you'll have to compromise a little. Just don't buy Invos, they suck.
2014 Roush best wheel/Tire set up to hook? jamyzd30 Roush Mustang 5 01-01-2016 12:29 PM
Need 12v under hook, need help with headlight wiring dseg 2011-2014 Mustang GT 0 06-17-2015 09:49 PM
Need help with idle and rpm problems. Car hardly able to be driven 01Smoke 1996-2004 Mustang GT 6 09-16-2012 06:32 AM
Would I be able to fit 16 or 17 in wheels on a 15 inch tire? sk8brdkd Mustang Wheels & Tires 27 05-20-2010 02:33 AM
Building a engine that is able to take a turbo. Dom Pre-2005 V6 Mustang 26 04-12-2004 10:40 AM
01:12 AM
