Should I get 18" - Mustang Evolution
Old 01-20-2004, 07:39 AM   #1
Send a message via AIM to BlackInvader99
Should I get 18"
I have a 1999 Mustang V6 of course, but I want to order some 18 inch Cobra R Rims but someone told me that going to big will slow me down, should I go for smaller rims???
BlackInvader99 is offline   Reply With Quote
Old 01-20-2004, 11:10 AM   #2
Anytime you increase wheel weight, or mass, you'll increase the amount of power needed to turn them. There are superlight big wheels out there, but I don't know enough about their strength to recommend them.
Another downer is that it also takes more braking power to stop the car with bigger wheels. I'd recommend Cobra brakes too.
Don't know what you're doing with your car, but you could run the big wheels around town and keep your stockers for playing at the drag strip.
The main reasons the factory put the small rims on there were 1) cost and 2) acceleration/braking improvement in the weaker drivelines. They figured if you wanted the really good looking wheels you'd buy the GT or Cobra, I guess.
Tin Kicker
Peace, love, 'Stangs.
2003 White 3.8/Auto/No mods YET. Now considering what massive horsepower mod to do first.
Tin Kicker is offline   Reply With Quote
Old 01-20-2004, 11:56 AM   #3
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I personally really like 17's. They are big enough to give you good handling but light enough not to make your car suck.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-20-2004, 12:43 PM   #4
Danger Dude's Avatar
17's are the way to go
Old 01-20-2004, 04:10 PM   #5
tire's Avatar
Send a message via AIM to tire
well put, plus 18" tires are a big step up in price.
tire is offline   Reply With Quote
Old 01-20-2004, 04:46 PM   #6
Thanks for your input guys, I beleive I will get 17"....
Old 02-20-2004, 01:20 AM   #7
The bigger your tires are, the less miles will be put on your car. Also, your speedometer will read wrong, not that it matters much because nobody ever follows the speed limit
jwscorpio is offline   Reply With Quote
Old 02-20-2004, 08:11 AM   #8
tire's Avatar
no, it won't. unless you purposefully get larger tires, the overall tire height will remain the same and hence no speedo change.
Old 02-23-2004, 08:41 PM   #9
I liek gramer
WhiteStang99's Avatar
would these 18" tires work for our cars? I know it says Corvette tires, but those are pretty dadgum cheap for 18"s...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2461567933
Old 02-23-2004, 08:44 PM   #10
only two of those tires are for 19 inch rims. The other two or 245/35/17's which is what a stock gt has on it
Old 02-24-2004, 02:58 PM   #11
I liek gramer
good point.. nick cant read...
Set of 4 Craftsman Quick Release Ratchets: 1/4", 2x 3/8", 1/2" fast64 Mustang Parts for Sale and Wanted 1 11-02-2009 12:31 PM
MTI RACING "Extreme Velocity" 454 "Southern Stingray" C6/Z = Awesome JROC Pictures and Videos 10 10-26-2007 03:33 AM
w0000ttt!!!!! got something today (starts with "s" ends with "upercharger") fast64 Pictures and Videos 37 02-22-2005 05:52 PM
10:21 AM
