Tire Pressure? 275x40x17 - Mustang Evolution
Old 04-07-2004, 08:10 AM   #1
Shahrum's Avatar
Send a message via MSN to Shahrum
Hey everyone,
When I got my tires mounted last night they were all filled to 32psi. On my old tires (the stock ones) I believe I was running at 35. Should I put these 275x40's up at 35 too?
Shahrum is offline   Reply With Quote
Old 04-07-2004, 08:36 AM   #2
Danger Dude's Avatar
Actually that depends on the tire. Somewhere on the tire should be reccommended tire pressure and that is what I would use on the road. We dont want to have a problem with temp build up with to little pressure as was the problem with Ford Explorers and Firestone. Ford suggested under inflation to get a better ride and that did not work to well did it!!!! Now on the track you can drop pressure some to get better launched!!!
Old 04-07-2004, 08:50 AM   #3
Shahrum's Avatar
So you're saying I should go with the recommendation on the tire and not the one in the globebox? I thought the weight of the car still determined what PSI you should run at and that's why they posted it in the car? Either way... I don't think my car has 275x40x17 in the glovebox, just the 205 and 255 maybe.
Old 04-07-2004, 09:00 AM   #4
Those PSI numbers are based on weight of the car. I suggest following the tire manufactures numbers before Car manufacture numbers. I say go with tire numbers and monitor your tires wear and if the outside is wearing to fast make sure you are in alignment and increase pressure by a slight amount if the center of the tire is wearing and the outside threads are not wearing back down the pressure slightly. But in all actuallity the fluctuation of a couple of PSI is nothing to worry about.
I say go with whats on the tire!!!
Old 04-07-2004, 09:58 AM   #5
Shahrum's Avatar
Thanks Corey -- I appreciate the advise!
no fuel pressure ? Chasity 2005-2010 Mustang GT 12 06-30-2009 07:42 AM
Tire Pressure? runvsofthisbull Mustang Wheels & Tires 9 02-01-2008 01:02 PM
tire pressure ryanxup Pre-2005 V6 Mustang 3 09-30-2006 03:07 PM
ideal track tire pressure...17x9 tedness Mustang Wheels & Tires 4 10-20-2005 07:25 AM
01:49 PM
