tire size - Mustang Evolution
Go Back   Mustang Evolution > General | Audio | Detailing | Wheels | Track | Regional > Mustang Wheels & Tires
Closed Thread
Old 06-09-2004, 06:10 PM   #1
STEVE is unknown around these parts
tire size
i bought some 18x9 black bullits now i want to know what kond of tires i should get like 265/40/18 i dont know what i should get i dont know what exactly those number mean. any help will be useful thanx.i have an 02 mustang
STEVE is offline
Old 06-09-2004, 06:25 PM   #2
i dont want any rubbing
STEVE is offline
Old 06-09-2004, 07:09 PM   #3
Falcon's Avatar
Falcon is unknown around these parts
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
265/40r18 will fit the r18 part is just stating the rim size so like a 17 inch rim will have a tire of r17 and 18incher will be r18 etc.. many people do 275's, but if u are lowered on an 18 inch rim you would most likely encounter rubbing
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline
Old 06-10-2004, 05:33 PM   #4
wow just looked for tires and they are really expensive
STEVE is offline
Old 06-10-2004, 05:57 PM   #5
Terminator Owner
SpectorV is just getting started.
well being that you have 18's you should run a 265/35/18 or a 275/35/18 you should hae no problem rubbing unless yoru rim has funky backspacing and offset. if the rim is set up for a mustang those should be fine, i have 17's with 275s and droped and i dont rub any.
do the MATH its very easy... take a stock ride height tire, 245/45/17 to figure out the side wall height just say 245 * .45 (the side wall height in this caseis 45% of the width, 245) thats your answer in mm. now you have 18s... so you need to take that into account, your side wall needs to be maller to keep the over all diameter the same. so you need the side wall to be one inch shorter over all, or .5 inch shorter on each top and bottom. you have to convert inches to mm's its 24.5 mm per inch, so you need a side wall that is (245 * .45 ) - (24.5 / 2)
i think if you do the math you will come up with a 265/35/18 will come very close and a 275/35/18 will be a tad to tall, you cant get it perfect just get as close as you can. if you can go wtih 275's cuz they will protect the rim lips better from curbs.
SpectorV is offline
Old 06-10-2004, 06:45 PM   #6
where can i go for the best price i just find 200 dollars per tire
STEVE is offline
Old 06-10-2004, 09:32 PM   #7
Terminator Owner
for an 18 inch ... you better be prepared to pay alot and buy tires pretty often lol go to tirerack.com their prices are nearly as good as it gets.
SpectorV is offline
Old 06-10-2004, 10:40 PM   #8
Laser02 is unknown around these parts
You will rub if lowered on an 18" rim with 275/35s. Period.
And 275s will not protect your lips. At all. I've gotten probably 5-6 curb rashes. The slightest bump of the curb will **** up your lips on an 18" rim w/ 275s. The sidewall is dead even with the lip. No protection at all. But it looks so sweet.
Laser02 is offline
Old 06-10-2004, 11:17 PM   #9
Terminator Owner
it is NOT period.... the rim offset and backspacing have a major effect on if you rub or not.... dont forget that, but regardless you will probably rub a little.
if you have a 9 inch wide rim and a 275 it should protect it, i have hit some curbs very hard and not a scratch on any of my rims. but differnet brand tires are all a little different so you never know.
SpectorV is offline
Closed Thread
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
tire size cas1 General Car Discussion 1 01-01-2008 09:32 AM
tire size stang-rookie Mustang Wheels & Tires 2 05-15-2005 02:54 PM
Need a tire size horess05 Mustang Wheels & Tires 10 05-21-2004 08:41 AM
Tire size Help 35thAniVertible Mustang Audio & Video 1 11-03-2003 01:23 PM
01:21 AM
