Shocks/Struts Install help - Mustang Evolution
Old 10-31-2004, 06:04 PM   #1
To take off the struts all I have to do is remove the strut nut and everything should come out right?
Old 10-31-2004, 06:24 PM   #2
Danger Dude's Avatar
Yes if you have the car on jack stands and the compression on the springs is released
Old 10-31-2004, 06:47 PM   #3
Awsome
Shocks and Struts should be in tomorrow and hopefully will be on Sat night
Old 10-31-2004, 09:10 PM   #4
fastmustangs1's Avatar
Thumbs up
Yes,but listen you have to jack up the front of the car and support the front lower control arm. The spring will pop out when removing the upper strut nut. Put the front on jack stands and use the floor jack to support the control arm. Shoot off the nut first, then lower the jack slowly. Also disconnect the tie rod ends. BE CAREFUL THE FRONT IS UNDER A LOAD OF PRESSURE ESPECIALLY THE FRONT SPRINGS!!. Good Luck,
Matt
fastmustangs1 is offline   Reply With Quote
Old 10-31-2004, 11:47 PM   #5
Zim
You want to **** me?
Zim's Avatar
youre gonna have to remove the front calipers / rotors
I like toys
Old 11-01-2004, 01:18 AM   #6
We installed the srpings ourself so we know what we are doing, just needed to know if thats the only thing that needed to be removed.
shocks/struts Sublime782 Pre-2005 V6 Mustang 15 05-15-2007 02:06 PM
shocks and struts all8280bcc 1996-2004 Mustang GT 8 03-01-2007 01:49 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 10:34 PM
shocks and struts install how to STEVE Pre-2005 V6 Mustang 6 05-25-2005 12:40 PM
Shocks..struts Exit_In_Red Pre-2005 V6 Mustang 6 12-01-2004 11:33 PM
11:12 AM
