5th Gear Issue - Mustang Evolution
Old 11-01-2004, 08:34 AM   #1
Send a message via Yahoo to cagedthought
5th Gear Issue
I own a 2001 V6 stang and have an issue with the 5th gear. Sometimes when im shifting into 5th gear at a high RPM (4000-4500 rpm) it grinds. Is there a way to fix this?
thanks,
James
James
cagedthought is offline   Reply With Quote
Old 11-01-2004, 08:55 AM   #2
do u have a short throw shifter? if so it might be because of the leverage that you need to use to get it into gear. how many miles are on your car/transmission. if there is a lot it might the syncros in the tranny or it might just need a tranny flush. there are a few things that might be wrong. give som more details to narrow it down.
bigpomps is offline   Reply With Quote
Old 11-01-2004, 09:41 AM   #3
97Stallion's Avatar
how fast are you going? Is this on the street or strip. In 4th at 4500, you're close to if not over 100mph depending on gears. But it could be you needing to hold the clutch in longer, or your syncros for the gear are going bad. That's an odd gear to go bad though. You must slam in to 5th alot.
Living one day at a time!
Old 11-01-2004, 11:49 AM   #4
It's s 2001 mustang v6 with 47xxx miles . I dont slam in into 5th gear alot i just drive it but i do get up on it every once and awhile. I installed a shorter shifter lever but its not a actual short shifter, its more so one of those smaller bolt on ****er arms. It doesnt happen to often just every once awhile.
James
Old 11-01-2004, 12:05 PM   #5
97Stallion's Avatar
I don't know what to tell ya. Can you feel if there any slack in your clutch pedal?
Old 11-01-2004, 12:09 PM   #6
thanks,
James
Remove transmission (takes about 1 hour) and take it to a transmission shop.
Had the same problem, and it was just a worn syncro. Cost me $50 for repair since I did all the heavy work.
For 5th gear problems, they only have to remove the tailshaft = cheaper repair.
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
4th to 5th shifting issue and hard as hell get into R - Black_Sunshine Pre-2005 V6 Mustang 7 03-18-2010 09:55 AM
5th gear grinding eddie1 1996-2004 Mustang GT 0 11-01-2008 12:54 PM
5th gear problem Murph00 Pre-2005 V6 Mustang 4 11-11-2004 08:39 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
06:13 PM
