fuel tank and radiator issues... - Mustang Evolution
Old 11-01-2004, 05:17 PM   #1
mustangmare's Avatar
i was filling up today when i saw a stream of gas coming out of my bumper. I tried to see the source but gas evaporates way to fast. I have also noticed my mpg lowering quite a bit. It goes down during the winter but not this much. Any one have this issue/know of it or anything?
Also, I have an antifreeze leak. I believe it is a timing cover because i can't see the source, but does this sound accurate? Oh, btw its a 1997 convert with 3.8L engine 76,000 miles on it. Thanks!
mustangmare is offline   Reply With Quote
Old 11-01-2004, 08:09 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
GET THIS CHECKED OUT AS FAST AS YOU CAN!!! If your gas leak is htat close to your exhaust then you're looking at a possible fire / explosion hazzard!! Get it to a Ford Dealer (or other mechanic) as soon as you possibly can!! Dont screw around with gas leaks!!
Antifreeze does not enter your timing chain cover... oil does. Oil and antifreeze dont mix. Check your water pump gasket seal. Check upper and lower radiator pipes. Check Head gaskets. Check oil dipstick (if you see a beade of water in your oil.... hehe, have fun.).
Rellik is offline   Reply With Quote
Possibly Fuel Leak, Gas Tank Mustang1804 1996-2004 Mustang GT 33 04-03-2010 10:46 PM
engine issues... no codes... fuel pump video added jimmy_beaner 1996-2004 Mustang GT 99 05-02-2009 12:56 PM
Fuel Tank/filler neck Scut95 1979-1995 Mustang GT 8 11-26-2008 02:15 PM
Fuel pump issues! Can anyone help? Stangbaby302 1979-1995 Mustang GT 5 04-13-2008 01:44 AM
08:11 AM
