MSD Window Switch Question - Mustang Evolution
Old 07-23-2003, 02:38 PM   #1
Has anyone installed a MSD RPM Activated window switch?
How the heck do you install it on a Distributorless ignition?
Instructions say something like, "Hook yellow wire into coil..." and i stopped right there, theres no coil wire on my car, bah!
Joshness is offline   Reply With Quote
Old 07-23-2003, 02:47 PM   #2
Danger Dude's Avatar
You hook it into the tach wire !!!!!
Old 07-23-2003, 03:05 PM   #3
Monkey's Avatar
you have to buy an adapter too
Old 07-23-2003, 04:25 PM   #4
Why do you need a adapter
Old 07-23-2003, 04:47 PM   #5
Called MSD, they said I need a Dis-Tach adapter.
Hooks into the Positive wire that goes into the Coil pack, then has an output wire to the RPM Switch.
Theres nothing to hook into a "Tach Wire" - its all electronic, and the switch needs a signal to detect the RPMs, so hooking it to the Tach wouldnt really work.
Old 07-23-2003, 06:54 PM   #6
Monkey's Avatar
that reason i just remember our cars needed a special adaptor
Old 07-23-2003, 07:15 PM   #7
what adapter I just got a MSD window switch and I see no need for a stinking adapter I could be wrong but what does this thing look like
Old 07-23-2003, 07:21 PM   #8
Monkey's Avatar
i never had one, but everyone i talked to and from everything i read said that for some reason a window switch could not be functional on our cars because of the way the tach is set up.
its the same reasoning behind needing to get an adapter to put a new tach in... like a larger one or a shift light. it doesnt have a wire in the back of it controlling it
Old 07-23-2003, 07:43 PM   #9
You also have a 98 though. Maybe they changed it all in the 99+ ?
I know the 99+ are all distributorless ignition systems. The tach, speedo, firing order, etc., are all controlled by the Computer. Thats why in the pre 99s you get a simple little plastic gear to adjust the speedo if you got a 3.73 rear end (or whatever size), and in 99+ you need a speedcal or a chip(diablo, etc) - all electronic. The gauges all work on the amount of voltage sent to them, not a RPM reading.
Since it is a distributorless Ignition, the computer sends the pulse to "fire" through a positive signal wire into the Coil Pack, which has multiple ground wires. The MSD Dis-Tach taps into that Positive wire and gets a true, exact RPM reading. That then connects to the Window Switch, then on to the Relay, Master Switch, WOT Switch, and Solenoids... you get the idea.
However, Id still be interested to see how your setup works, because If I can get away with not having to spend another 50-75 bucks on this thing, then so be it.
Pic doesnt show wires, but theres a Ground, a Posi In, Posi Out, and Signal wire out (that goes to the window switch)
Old 07-23-2003, 07:44 PM   #10
somewhere in the ignition system is a tach wire I will find it
Corey
Old 07-23-2003, 09:41 PM   #11
Monkey's Avatar
pre99s have a distributorless system too. they never put distributers in the SN95 models.
the reason we have a speedogear is not all the electronics y'all do, but they had to make adjustments when they went returnless fuel system, so they put the electronic control on the speedo. youre forgetting the speedo gear is inside the tranny. it is controlled and monitered electronically too. it sends the signal to the computer which then controls the speedo.
Old 07-23-2003, 10:20 PM   #12
94-95 5.0 SN95's had distributors!!!!!
Old 07-23-2003, 10:41 PM   #13
Monkey's Avatar
i was talking about SN95 V6s. 5.0s are a different class in my book
Old 07-24-2003, 08:21 PM   #14
Send a message via AIM to Squirrel
Whats a MSD window switch?
Danny - In need of a mustang.
Squirrel is offline   Reply With Quote
Old 07-24-2003, 08:31 PM   #15
Monkey's Avatar
read the nitrous sticky. only keeps nitrous on while in a certain RPM range "window" if you will
Old 07-24-2003, 08:43 PM   #16
OOOO i gotcha. man brandon your just so smart.
Old 07-29-2003, 03:02 PM   #17
Sheesh. On 94-98 you can tap the tach wire coming out of the ecu or going into the cluster, no adapater or modified window switch is necessary. For 99+ you need a tach adapter, I sell them and so do a bunch of other places.
For 94-98 see the www.supersixmotorsports.com site for instructions, you would hook it up like a tachometer.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 07-29-2003, 05:07 PM   #18
justin00stang,
You sell the adapter? How much? Need it for an 02 v6
Old 07-29-2003, 05:47 PM   #19
65 shipped, email me vmperf@bellsouth.net
I've got one of the adapters on my car, it works great.
Justin Starkey
Old 07-31-2003, 03:36 PM   #20
justin00stang,
Thanks for the offer, but used my discount at summit and got the MSD part for $40 shipped. 65 shipped is a good price though for others who might be interested.
Old 07-31-2003, 03:47 PM   #21
Nice. How much is retail on the msd part? maybe I need to consider it.
Old 08-01-2003, 06:15 PM   #22
Retail is $59 - thats why I said 65 shipped is a good price. But I had a $20 Discount from Summit that I used. (for msd... and IMO MSD > FRPP )
Old 08-04-2003, 12:13 PM   #23
Damn I paid like 80 locally for mine . Oh well
Question about a switch PenguinFan Mustang Wheels & Tires 7 05-05-2009 06:58 PM
Need Advice-Baker Electorics-Window Switch RWS/ARWS TafoyaMNAA Pre-2005 V6 Mustang 3 06-15-2007 03:24 PM
window question Anvil5646 1979-1995 Mustang GT 0 08-09-2006 04:46 PM
Window Up/Down Question StreetRacer4371 Mustang Audio & Video 1 10-15-2005 09:43 PM
driver side window motor / switch ? Dark02Pony Pre-2005 V6 Mustang 2 06-21-2005 10:02 PM
10:32 PM
