8.8 rear end - Mustang Evolution
Old 11-04-2004, 04:53 PM   #1
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
8.8 rear end
I'm checking into a new rear end (with t-lok of course) for Christmas...would either of these older model 8.8's work in my 2000 3.8 5spd? Also could someone tell me where I should get one new (for best price)
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Thanks...
and, I would need rear gears with this, is that the only other thing it would cost other than installation?
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 11-04-2004, 05:04 PM   #2
KyleUSAF's Avatar
oh, and (I know I am stupid ) but what exactly are the benefits of upgrading to an 8.8
Thanks
Old 11-04-2004, 05:05 PM   #3
An 8.8 will simply hold up to more abuse.
Old 11-04-2004, 05:15 PM   #4
Monkey's Avatar
first and foremost - If you get an 8.8 from anything before 99, then you wheels will be sunken in more.
Just be warned, a rear end weighs over 75lbs but usually over 100lbs. Shipping will run you at least $100. Don't forget to add that to the price.
You can do the install yourself very easily. There are only 14 bolts that hold the rear end on. You just need 2 jackstands and a jack and some sockets ranging from 15mm to 21mm
btw, both rears will bolt right up
Old 11-04-2004, 05:25 PM   #5
KyleUSAF's Avatar
how much farther in? I mean, is it going to be noticable, and will 18x9.5" wheels fix kinda (but not any time soon ) also, is this mod worth it if i plan to eventually mod it out or should i get other mods before i get this, because it wont be needed until maybe, a lot more mods...
Thanks
Old 11-04-2004, 06:02 PM   #6
Monkey's Avatar
if you plan on getting a power adder (nitrous, turbo, super) then yes, get it.
it will sink the wheels in by .75" on each side. Enough to be visable. Wheels could fix it, depends on the backspacing though
Old 11-04-2004, 06:08 PM   #7
KyleUSAF's Avatar
thanks, i found and read an earlier thread jimmy_beaner made asking basically the questions i had. I do plan on eventually supercharging [ ]so i guess i will search and save until i can get one. i think i just want to get one out of a 99+ gt so those ebay listings are not an option...i shall check the junkyard and i checked the sites you had posted and none was found. l think my limit on $ would be around 300 for Christmas so... i can work making about 200 per week during Christmas break and then i will have to find one...[/ ]
Old 11-04-2004, 06:34 PM   #8
KyleUSAF's Avatar
this isnt what i want is it
http://store.summitracing.com/defaul...t=FMS-M-4235-E
Old 11-04-2004, 07:17 PM   #9
No, that's just the axles, not the pumpkin (big center portion that holds the gears)
Old 11-04-2004, 09:03 PM   #10
Monkey's Avatar
ask yourself -- do you REALLY plan on supercharging? EVERYONE always says the plan on going forced induction, but less than 10% even do it. The 7.5 can handle over 300hp easily, so if you are only thinking you want to do it. keep the 7.5
Old 11-04-2004, 10:38 PM   #11
Man. I've been planning on getting forced induction for like 12 years.
Laser02 is offline   Reply With Quote
Old 11-04-2004, 10:39 PM   #12
lol, we all have
Old 11-06-2004, 08:26 AM   #13
my supercharger hasent broken my 7.5 yet and put one on cause 13s in a v6 is a lot of fun. espically when you get to beat LS1s all day ... the LT1 chevys are a bit more of a challenge. Plan on spending money on a s/c, injectors,new fuel pump, chip ( and if they say it comes with one its not an off the shelf thing at all) You will need a posi rear end too and dual exhaust at the minimum to get real performance from it. So mabey do the rear and exhaust first and then when you got 4000.00 go with the supercharger.There are many Hidden costs you may not consider and places wont exactly tell you about them so they can advertise "the best price" injector harness, relocating the washer fluid container cause thats where the s/c goes on 99 and up and inner cooler is highly recomended, k/n filter that goes in your fender. non platnum plugs. Thats not even installed yet. droping the fuel tank to put in the new fuel pump is a *****. Mabey a 100 shot Zex for 500 bucks and a chip that will pull back your timing too 3-4 degrees ****** to avoid detination will be the chhepest way to go. BUT GET THE CHIP/TUNE to ****** the timing or anything over a 50 shot may hurt your engine. Espically if its hot out. GOOD LUCK!!!!!!!!
drive it like you stole it
smokin6 is offline   Reply With Quote
Old 11-06-2004, 08:37 AM   #14
Zim
You want to **** me?
Zim's Avatar
lt1's should be eaiser to beat than an ls1
I like toys
Old 11-06-2004, 09:45 AM   #15
Monkey's Avatar
i never said the 7.5 was a weak rear end. I was warning him that he doesnt need to buy an 8.8 if he isnt going FI. Heck, didnt Pete have a 7.5 for a long time in his car too? The launch is what really hurts the rear end, so if you are using it for highway races, 7.5 is fine
Old 11-06-2004, 02:54 PM   #16
Kiljosh's Avatar
I don't plan on upgrading my rear-end for awhile now, It's not necessary until your car is a god in the v6 world :p.
I say it's money that could be spent elsewhere for now.
Old 11-06-2004, 03:23 PM   #17
Monkey's Avatar
you you do what I did... 75 shot of nitrous with 4.10s and an aftermarket torque converter with slicks. That thing launched HARD. god bless sub 2.0 60's on a 98 V6 automatic.
Old 11-08-2004, 07:56 PM   #18
2.0 60 ft Sweet!!!!!
Old 11-08-2004, 07:58 PM   #19
way easyer my friends 11.6 sec Ls1 is the on that makes me
Old 11-08-2004, 08:06 PM   #20
I understand you didnt say it was week.. just wanted him to know that the 7.5 has been put to the test and passed in my eyes. When you play like Pete the 8.8 is the way to go. I do my racing at the track more than highway. the track eats drive trains. BYRON DRAG WAY in IL. I may be at the limits at about 345 tourque at the wheeles? ( only a estimate no dyno to prove it)
rear end v6stangracer Pre-2005 V6 Mustang 12 03-23-2005 09:41 AM
GT rear end CajunMustang Pre-2005 V6 Mustang 2 11-04-2004 11:34 AM
99-04 8.8 Rear end ManofManyStangs Mustang Parts for Sale and Wanted 3 10-20-2004 06:32 PM
8.8 Rear End ttpancakes Mustang Parts for Sale and Wanted 8 07-20-2004 06:39 PM
what is in my rear end. Black00GT Pre-2005 V6 Mustang 9 03-18-2004 03:33 PM
10:42 PM
