Some Questions about oil and OBD. - Mustang Evolution
Old 03-13-2009, 05:22 AM   #1
hi every body, this is my first post.
I just bought a 1996 stock v6 and was wondering:
I live in Israel, its realy hot and dusty here most of the year. what grade should i use. is semi synth enough? or do i need fs?
where is the obd connector?
is it obd1 or 2?
and i think thats it for now.
6opka is offline   Reply With Quote
Old 03-13-2009, 06:09 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Some Questions about oil and OBD.
is it obd1 or 2?
I want to say OBD2, and it should be under the driver's side dash.... as in above where your feet go when you're driving.
Being really dusty, the most important thing will be your air filter. Definitely remember to 1) change it frequently if you stay with a stock filter, 2) clean the filter if you get a CAI. I would use full synthetic. The car calls for 5W-20, but you may consider 5/10W-30 full syn.
Old 03-13-2009, 06:14 AM   #3
should i use 5w40 fs?
Old 03-13-2009, 06:21 AM   #4
Region: Iowa
I don't know if I would go to 40.
Old 03-13-2009, 06:24 AM   #5
its just that i can get it for pretty cheap but im afraid of using 5w40 instead of 5w20 or 30..? is it ok to use it?
Old 03-13-2009, 06:27 AM   #6
Region: Iowa
you might be able to get away with it. Do you drive it easily, or do you drive it like you stole it?
Old 03-13-2009, 06:33 AM   #7
usually i drive easily, but i do push the pedal from time to time.. what can it effect?
Old 03-13-2009, 10:40 AM   #8
well, i used 5w40, i think it runs ok..
Old 03-13-2009, 10:12 PM   #9
hottcobra's Avatar
first off welcome to the site.
5w40 is not gonna hurt the car at all. I would try to find a 10w30 or 10w40. It doesn't have to be syn at all. but I would get a higher weight than 5. The weight determines how thick the oil is going to be. the hotter the outside temps the heavier the weight you should use. ie. heat thins out the oil, and heavier oil is thicker and will not become too thin in high temps.
Old 03-14-2009, 01:03 AM   #10
I see, well its pretty hot around here. i guess the next time I'l service the car I will use 10w30or40.. and thanks for the welcome and help.
Old 03-14-2009, 09:24 AM   #11
hottcobra's Avatar
anytime
OBD II and Ford EEC ports? Otlaw80 1979-1995 Mustang GT 4 01-13-2011 11:51 PM
Oil upton7 The Bar 0 12-27-2009 04:27 PM
oil carlosc Pre-2005 V6 Mustang 46 02-25-2009 07:35 PM
Cheap OBD-II to Laptop with converter AirBrontosaurus Pre-2005 V6 Mustang 9 08-02-2006 02:39 PM
Oil changing questions. For a mod newb saleen0027 1996-2004 Mustang GT 22 07-15-2005 04:56 PM
02:01 PM
