Stock drive train specs and modding advice for V6 Mustangs - Mustang Evolution
Old 11-09-2004, 05:19 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
In 99+ cars the stock rear end gears are 3.27s
Pre 99 cars are 2.73s
For an auto tranny the suggested gearing is 4.10s
And for manuals it is 3.73s.
Now remember that in 99+ cars you need to have a chip to recallibrate the speedo. And donít forget the T-lok for improved traction.
In pre 99 cars gears and t-lok have been proven to take .5 off the ľ mile. 99+ cars get about .3 on the ľ mile because they have better gears stock.
Shift kits
From what I have been told stay away from both B&M and Trans-Go shift kits for both the 99+ trannys.
As for pre 99s I was told go with Trans-Go shift kit.
Torque converter
For a 99+ car you want to go with a Stallion 3000 stall. They blow away their competitors.
For a pre 99 car you might want a slightly tighter converter, some thing no higher then 2800 stall.
Transmission Gearing
.....................1st.....2nd.....3rd.....4th.....5th
...........T-5.....3.35...1.93....1.27...1.00....0.73
...........AOD....2.40...1.47....1.00...0.67
(4R70W)AODE..2.84...1.55....1.00...0.70
2005 T-5........3.35...1.99....1.33...1.00....0.68
Written By Michael Welch,
and thanks to Rob for his help
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 11-09-2004, 05:32 PM   #2
Monkey's Avatar
by tighter, do you mean less stall? I would not recommend anything over 2800 stall for a pre99
don't forget to mention that pre99s can use either the Speedcal or a 23 tooth speedo gear put into the tail shaft of their trannies to correct their speedos
Old 11-09-2004, 06:06 PM   #3
99+ manuals can also just use a speed cal
Old 11-09-2004, 06:26 PM   #4
Danger Dude's Avatar
There is different gearing in the auto tranny's between 94 to 97 and 98 on 1998.......1st......2nd.....3rd......OD
4R70W...2.84....1.56....1.00.....0.70
Old 11-10-2004, 08:26 AM   #5
there are diff gearing sets for the manual also. some only have a 3.33 first and there are others that are like 2.89 or so first as well.
speedcals will work on some autos also, pre 97s i do belive.
Old 06-28-2005, 10:55 AM   #6
Send a message via AIM to tedness
get a tuner such as an SCT unit and recalibrating it that way also works. plus you're killing 2 birds w/ one stone.
tedness is offline   Reply With Quote
Old 06-28-2005, 11:17 AM   #7
97Stallion's Avatar
That only works for 99+ Mustangs. The 94-98 Mustangs used speedo drive and speedo driven gears. You can not buy a Chip and have them calibrate your speedometer for these years.
Living one day at a time!
Old 06-28-2005, 01:49 PM   #8
ah thnx for the correction.
v6 mustang
drive train question. Paincake1 Pre-2005 V6 Mustang 2 09-05-2008 11:41 PM
Hello from Russia. Please advice wheels & tires for stock 95 mustang GT SandMartin General Mustang Discussion 4 07-15-2008 07:22 AM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
Gears and Drive train XxV8 MuStAnGxX 1996-2004 Mustang GT 17 02-04-2006 07:55 PM
So you think mustangs look like 4x4's stock eh? look here sonic04edge Pictures and Videos 10 04-29-2005 04:14 PM
05:09 PM
