What are the part differences between 3.8 and 4.2 - Mustang Evolution
Old 11-14-2004, 03:20 AM   #1
Send a message via MSN to StangCrazy
Other than crank and rods, do the blocks differ in any way? Are the rod and main caps, bolts and oil splash tray the same? Any other engine components different?
StangCrazy is offline   Reply With Quote
Old 11-14-2004, 04:14 AM   #2
Monkey's Avatar
blocks are identical. you can throw a 4.2 block in your 3.8 and just change the upper manifold so that it will clear the mustang hood.
Old 11-14-2004, 05:55 AM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
^wordizzle
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 11-14-2004, 11:23 AM   #4
97Stallion's Avatar
The 4.2 is identical, but it's equip'd with knock sensors. That's the only difference in the block that I know of. Depending on the year of your car, you'e going to need a difference flywheel, oil pan, oil pick-up tube, and balancer. Also the pistons are different.
Living one day at a time!
differences in 06 07 08 gt onequickR 2005-2010 Mustang GT 18 05-06-2009 09:17 AM
supercharge and turbocharge differences cmanzi79 General Mustang Discussion 7 01-18-2006 11:58 AM
Cam differences...just a thought Vinnietbird 1979-1995 Mustang GT 4 10-22-2005 12:14 PM
differences evilweirdo42 Pre-2005 V6 Mustang 6 11-23-2004 09:26 AM
10:19 PM
