When a good Nitrous WOT Switch Goes Bad... BOOM!! - Mustang Evolution
Old 11-14-2004, 02:46 PM   #1
On my third run Friday, the WOT switch hung up, so when I shifted it kept spraying. When I punched the throttle open, a flood of n20/fuel hit the intake and boom! Grenade action.
Luckily, I was only using a 50 shot.
Engine is just fine after putting the ported SPI intake back on.
Still have to find a hood Monday...
[/img]
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 11-14-2004, 03:10 PM   #2
I liek gramer
WhiteStang99's Avatar
wow. looks pretty serious...
Glad you're alright and so is ur car for the most part.
Old 11-14-2004, 03:21 PM   #3
Found a CAPA hood locally for $120 and the hood scoop for $80, paint will be about $100.
Could have been alot worse, was just a big surprise hearing the pop and watching the hood blow upward about 16 inches.
Old 11-14-2004, 03:24 PM   #4
Fishers Stang's Avatar
dang
Charles
Old 11-14-2004, 06:15 PM   #5
Monkey's Avatar
so the WOT switch got stuck closing the circuit, so the nitrous was freely flowing the whole time?
Old 11-14-2004, 06:37 PM   #6
dont they have some sort of catch that if it stays open more than so long it will cut off autmatically
Old 11-14-2004, 07:08 PM   #7
wow, sucks. i wanted nitrous but not after seeing this
Old 11-15-2004, 02:49 AM   #8
Send a message via MSN to StangCrazy
Did you have to change your shorts after the big bang?
That is on big AH *****
StangCrazy is offline   Reply With Quote
Old 11-15-2004, 08:58 AM   #9
The switch stuck closed and kept spraying as I let off the throttle and began my shift. It must have had a good little puddle of fuel/n20, because when I opened up the throttle... BOOM!
Just a flash and the hood jumped up. No scorch marks anywhere but inside the intake itself.
Car is running fine with my ported intake, just have to find a hood, get it painted and I'm back on the road.
Old 11-17-2004, 06:29 AM   #10
same here , i was gonna get this for xmas but now ill just spend the 400$ on a flasher chip
InVaDeR is offline   Reply With Quote
Old 11-17-2004, 08:01 AM   #11
Zim
You want to **** me?
Zim's Avatar
guys dont let an accident like this make you believe nitrous isnt safe. Thats kind of a freak occurrance to have the WOT switch stick like that. If youre really concerned, just buy two WOT switches and run them in series so you cut the chances of this happening in half.
I like toys
Old 11-17-2004, 01:43 PM   #12
But... This is a great example of why you should not run a wet system into an EFI intake.
http://www.fordchip.com
Featuring Superchips Custom Tuning products
'99 4.2L 5-spd, Powerdyne, CNC'd heads, 211/.523 cam, 70mm TB, 1.8 RRs, JBA headers, custom X off-road, 90mm SCT, 60#s, Mach I duals, Ripper, PHP 8.8, Steeda UCAs, LCAs, 3.73s, Alum driveshaft, 245/45R17s on Silver Bullitts
11.3 @ 122 (ET Streets)
465 rwhp/460 ft/lbs (25hp dry shot)
12/00 MM & FFs, 7/01 5.0 & Super Ford, 2/02 Hot Rod
pete is offline   Reply With Quote
Old 11-17-2004, 01:52 PM   #13
Danger Dude's Avatar
DOOOOHH!!!!!!
Old 11-17-2004, 02:39 PM   #14
Zim
Zim's Avatar
To me, dry systems are scarier than wet just cause I dont trust the computer to add enough fuel that quickly all the time. I dunno, each have their benefits and downfalls... I just chose to go with a wet system.
I like toys
nitrous
Sumitomo Tires Good or Bad HELP! ponyboy94 Pre-2005 V6 Mustang 12 04-02-2010 07:43 AM
The Good The Bad And The Evil EVILUTION GhosT New Member Introductions & Greetings 25 12-23-2007 08:07 PM
when good drifting goes bad: Thomas91169 Pictures and Videos 9 06-15-2007 01:47 PM
Good or Bad? You decide PureVenom The Bar 20 07-27-2005 12:29 PM
argh, i want nitrous so bad. Monkey The Bar 10 05-22-2005 02:42 PM
09:06 AM
