Biggest shot of nitrous on stock V6 - Mustang Evolution
Old 11-15-2004, 02:29 PM   #1
What is the most nitrous a stock 99 V6 mustang can handle on stock internals? I had a 100 shot on it and it still runs smooth I ran a 14.3 with 100shot, but am thinking of adding a 125 shot jet. Is this safe? Will the stock motor handle it? And how much horsepower can a stock V6 handle? Thanks
MatrixJK4 is offline   Reply With Quote
Old 11-15-2004, 02:44 PM   #2
I haven't heard of anyone running over a 100 shot on a completely stock motor. I personally wouldn't ever run that much on a stock motor. It's just a matter of how much you trust your engine to continue running after having that much happy juice run through it
Old 11-15-2004, 03:08 PM   #3
Zim
You want to **** me?
Zim's Avatar
im runnin 100 shot and wouldnt go any higher
I like toys
Old 11-15-2004, 03:16 PM   #4
Yeh..I've always heard horror stories of melting the whole inside of the engine with much more than that lol
Old 11-15-2004, 03:48 PM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
I've never heard of a split port running a 100 shot on it, safely. The single ports can because of the six runners instead of twelve.
Old 11-15-2004, 10:12 PM   #6
Monkey's Avatar
the split ports can run a 100 shot about half the time. it is safer on the single ports.
read the sticky in Gen Mustang Tech. It goes into detail on this topic.
Old 11-16-2004, 09:53 AM   #7
I will be running a 100 dry shot, I know of another guy who will be running a 125 dry shot.
Only wet shots are dangerous on a splitport, dry shots are fine as logn as you have the fuel components to back it up.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 11-16-2004, 11:20 AM   #8
Danger Dude's Avatar
What he said. 100 shots are OK as long as you have a properly tuned Chip or program. 100 dry shot Split port 100 wet shot Single port. But for all around fun 75 shot is safer.
Old 11-16-2004, 12:46 PM   #9
With injectors, MAF, pump and dyno tune you can run 125+. You just need to verify its A/F.
http://www.fordchip.com
Featuring Superchips Custom Tuning products
'99 4.2L 5-spd, Powerdyne, CNC'd heads, 211/.523 cam, 70mm TB, 1.8 RRs, JBA headers, custom X off-road, 90mm SCT, 60#s, Mach I duals, Ripper, PHP 8.8, Steeda UCAs, LCAs, 3.73s, Alum driveshaft, 245/45R17s on Silver Bullitts
11.3 @ 122 (ET Streets)
465 rwhp/460 ft/lbs (25hp dry shot)
12/00 MM & FFs, 7/01 5.0 & Super Ford, 2/02 Hot Rod
pete is offline   Reply With Quote
nitrous
Not the biggest Ford fan, but... MarkuzLS1 The Bar 11 10-03-2006 12:00 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
biggest parental lies Kyle The Bar 28 06-09-2005 09:59 PM
stock internals and nitrous tedness Pre-2005 V6 Mustang 16 02-13-2005 11:33 PM
why would modest psi and 35 shot be so bad on stock motor? tire Pre-2005 V6 Mustang 14 12-21-2003 10:41 PM
01:47 AM
