Hot start idle issues - Mustang Evolution
Old 03-18-2009, 10:37 AM   #1
Scorpion1's Avatar
Every now and then if I rip on it for a bit or drive in a rushed fashion it seems that if I turn the car off and come back within 30 minutes and start it again the idle will bounce from 450-1200rpms and if I give it gas it bogs and bounces harder. I have yet to just wait it out if I restart the car (usually no more than two times) it seems to recover and acts like it never happened. Just holding the RPMs up for a bit doesnt seem to make it go away it just goes back to bouncing around. ANY suggestions? It almost feels like a cylinder is down, but once its gone it runs smooth as new.
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 03-19-2009, 09:07 AM   #2
1234's Avatar
Re: Hot start idle issues
The only thing that comes to mind is the EGR valve is sticking.
Old 03-19-2009, 09:13 AM   #3
Scorpion1's Avatar
Thanks for the suggestion, is there any way to check it without removing it or rather replacing it? I got $7 in my account lol.
WiCK3D_SiX
Old 03-19-2009, 09:17 AM   #4
1234's Avatar
You can wait till it does it again. When it does pop the hood and pull the vacuum line off of the egr valve. If the car sputters and dies then the egr valve is good. If it runs the same then the valve is not the problem.
Old 03-19-2009, 02:42 PM   #5
Scorpion1's Avatar
sweet thank you.
WiCK3D_SiX
Old 03-20-2009, 04:57 PM   #6
1234's Avatar
Let me know what you find out.
Old 03-26-2009, 10:01 AM   #7
Scorpion1's Avatar
Havent been able to reproduce the idle issues as of late, would cleaning out the EGR with CARB cleaner help anything or make it worse? Also I have a bent throttle spring which makes my throttle stick at the begining, can I get just a replacement spring? I cant seem to find them anywhere.
WiCK3D_SiX
Old 03-27-2009, 09:29 AM   #8
1234's Avatar
Carb cleaner wont hurt it. As for the spring you might try the dealer.
Old 03-31-2009, 09:39 AM   #9
Scorpion1's Avatar
Wed I will be removing the EGR system and cleaning it all out and Ill be replacing the throttle spring today hopefully. Advance Auto started carrying the return springs for $2.69 so Im quite happy lol. Ill keep everyone updated to see if this helps. Im probably also gonna try to clean out the throttle and such since Ill have the cleaner and be under the hood already.
WiCK3D_SiX
Old 04-01-2009, 05:23 PM   #10
Scorpion1's Avatar
Cleaned the EGR out today, car runs quite a bit smoother and havent had the issue yet but Ill post if it happens again. Also cleaned out the IAC Valve which seemed to help the idle a bit as well.
WiCK3D_SiX
Old 04-01-2009, 08:51 PM   #11
1234's Avatar
Nice glad to hear it.
Old 04-02-2009, 08:51 PM   #12
Scorpion1's Avatar
Yeah now I have a ticket to fight lol. 77.6 in a 55..somehow while following grandpas caddy at 65 and being passed on the right:
WiCK3D_SiX
Old 04-07-2009, 04:58 PM   #13
MonteCitan's Avatar
Wow that would suck, 22 over is a pretty high ticket
Take that one to court!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
You guys with idle issues (possible vacume leak) try this SpectorV Pre-2005 V6 Mustang 3 06-01-2010 01:28 PM
1995 GT cranks but no start hot 89beretta 1979-1995 Mustang GT 9 07-26-2009 08:23 PM
Will not start when hot SJLOGAN 1979-1995 Mustang GT 7 06-03-2007 09:02 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
weird engine idle when hot 232SCstang Pre-2005 V6 Mustang 4 03-27-2004 12:08 AM
12:57 AM
