Engine knocking sound (video inside) - Mustang Evolution
Old 11-15-2004, 11:46 PM   #1
Alright so my engine makes this noise (see video)
any ideas what it could be?
Old 11-16-2004, 12:11 PM   #2
Send a message via AIM to mustangmike524
yeh, mine sounded like that once it hit 2000 rpms, until i had to replace the engine...
mustangmike524 is offline   Reply With Quote
Old 11-16-2004, 12:15 PM   #3
Ha..you sent that to me last night, I dl it..just never listened. I have no idea what it might be though...
Old 11-16-2004, 12:41 PM   #4
Danger Dude's Avatar
Check the PCV valve first. pull the valve out of the passanger side Valve cover and then place your thumb over the hole on the bottom of the PCV valve and rev the car and see if it is still rattling
Old 11-16-2004, 12:43 PM   #5
Do you have roller rockers?
http://www.fordchip.com
Featuring Superchips Custom Tuning products
'99 4.2L 5-spd, Powerdyne, CNC'd heads, 211/.523 cam, 70mm TB, 1.8 RRs, JBA headers, custom X off-road, 90mm SCT, 60#s, Mach I duals, Ripper, PHP 8.8, Steeda UCAs, LCAs, 3.73s, Alum driveshaft, 245/45R17s on Silver Bullitts
11.3 @ 122 (ET Streets)
465 rwhp/460 ft/lbs (25hp dry shot)
12/00 MM & FFs, 7/01 5.0 & Super Ford, 2/02 Hot Rod
pete is offline   Reply With Quote
Old 11-16-2004, 01:22 PM   #6
Its a stock engine
Old 11-16-2004, 02:19 PM   #7
Fishers Stang's Avatar
well I went to take vid of what my engine sounds like, but I found antifreez all under the front of my car... cause 1. check the hose and water pump) < for me, but Brent, sounds like you need to get that checked out.. or wait till your 4.2 is done
Charles
Old 11-16-2004, 06:46 PM   #8
Sounds like a bent rod or a loose roller rocker.
CraZy6 is offline   Reply With Quote
Old 11-16-2004, 10:15 PM   #9
But would it not do that all the time if it was the case? It doesnt make that noise all the time.. i dunno me and brandon(spectorV) are going to change the plugs(see if I am running rich/lean or if they are gapped to much) and do a few othe rmainteance things monday probably. so we will see
Old 11-17-2004, 05:21 AM   #10
A loose rocker would make noise all the time and the cars performance would suffer badly
Old 11-17-2004, 05:27 AM   #11
Here is the best thing to isolate the noise. Get a hose about 2 1/2 ft long, put one end to your ear and the other to the engine. With the engine running and the car on ramps or jack stands. Start first at the valve covers then the upper intake, then move down to the oil pan. You will be able to better isolate where the sound is coming from.
Did you do the PCV check????? If the sound is coming from the oil pan you are screwed. You migh get lucky and only have a collapsed lifter which will be heard in the valve covers
Old 11-17-2004, 08:46 PM   #12
the engine knocking sound
Where is the sound coming from up top or down low?
If u let your car sit at idel what is does your rpm do and what does your oil pressure gauge do?
TheMustangKid is offline   Reply With Quote
Old 11-17-2004, 09:05 PM   #13
Oil Pressure is fine and it doesnt make this noise at idle.. .only when you give it gas or are going down the interestate and have your foot constantly on the gas
^ That leads me to believe its the cats which is what I hope for
Old 11-17-2004, 09:08 PM   #14
has there been any raw fuel dripping out the tail pipes?
Old 11-17-2004, 09:35 PM   #15
not that I can see
Old 12-02-2004, 08:06 PM   #16
How Many Miles Have You Put On Your Car Since You Got It? Sorry If I Sound Like A Dick But Judging By The Way You Were Revving Your Motor In The Clip It Sounds Like You Have A Lead Foot But I May Be Wrong. But You May Have Accidentally Overrevved Your Motor At One Point And Had A Valve Bend Making It Get Stuck Open And The Piston Comes Up And Smacks It Causing It To Close Again. I Know Mustangmike524 From School And His Did The Same Thing Resulting In A New Motor Like He Said. So You Should Probly Have That Checked Out. I Have Heard Of Cases Like This With Eagle Talons And The Valve Shot Through The Hood.
89'FIVE-O is offline   Reply With Quote
Old 12-02-2004, 08:08 PM   #17
Hehe, Brent has a heavy foot. O..and 89'Five-O, you don't have to capitalize the first letter of each word...
Old 12-02-2004, 10:41 PM   #18
I liek gramer
WhiteStang99's Avatar
He Didnt. It's An All Caps Filter! See! I'm Typing In All Caps.
Old 12-02-2004, 10:49 PM   #19
Haha, O
Old 12-02-2004, 11:32 PM   #20
Alright.. well wouldnt that do it all the time if that was the case?
And for the love of god hit your caps button
Engine Knocking NotoriousSPG Pre-2005 V6 Mustang 10 07-08-2010 04:42 PM
ticking/ knocking sound almostxevil Pre-2005 V6 Mustang 16 04-04-2007 06:29 PM
how does this sound?(long modlist inside) Thomas91169 1996-2004 Mustang GT 31 10-18-2005 02:29 PM
Knocking sound? Ibanezplayer272 1979-1995 Mustang GT 4 12-04-2004 10:43 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
11:37 PM
