car sound - Mustang Evolution
Old 11-16-2004, 05:00 PM   #1
Send a message via AIM to charkelly9
car sound
when i start my car in the morning (garaged) the engine temp says its absolutly freezing which i would expect. But then i when i start up my car it makes an annoying sound "shhhh" thats constant until the engine is completely warmed up this can take awhile... i dont think the car should sound this way.. when i accelerate the sound is even more evident.. do you have any idea what this could be.. it only has 15000 miles.. im thinking fuel injecters may be the cause?
charkelly9 is offline   Reply With Quote
Old 11-20-2004, 03:07 AM   #2
Send a message via MSN to StangCrazy
Couple of questions. Can you isolate the "shhhhh" sound to anywhere? (engine compartment or under the dash) Is this sound related to outside air TEMP? (gone when outside air is 40 and above). If the car has 15K miles on it, it is under factory warrantee until 36K (or longer if you have an extended Warrantee). I would let for "Ford garage" deal with it. If you can isolate the physical place where it occurs it should help the repair facility. I would think it is either a mechanical noise of a vacuum hose (or fitting) problem. I know I am not much help to assist you, but it is rather difficult to try to troubleshoot this over the internet. Keep us posted on what you find out and good luck.
StangCrazy is offline   Reply With Quote
Old 11-20-2004, 06:57 AM   #3
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Do you happen to have a cold air intake?
232stang01 is offline   Reply With Quote
Old 11-20-2004, 08:41 AM   #4
As long as you're under warranty, just carry it to Ford and let them figure it out
Old 11-20-2004, 11:29 AM   #5
it may be a noisy valve train but that would be ticking not a constant sound.
Old 11-20-2004, 04:58 PM   #6
i talk to him alot on aim so i know that he does have a cai
Old 11-25-2004, 09:25 PM   #7
Send a message via AIM to Mikes3point8 Send a message via Yahoo to Mikes3point8
Before I went with an aftermarket airfilter from K&N I heard a pretty loud sucking sound comming from the engine. Removing the aircleaner for the aftermarket one, the noise was much louder and always at startup. You might want to check if you have the stock air filter that the housing is closed correctly and all lines are connected.
Mikes3point8 is offline   Reply With Quote
Old 11-29-2004, 09:06 PM   #8
thanks guys im taking this car in... yes i have a cai ...but i dont think its what is causing this noise. I need to get my cd player (6) fixed bc it keeps jamming when removing and adding cd's i think the player has a factory recall- so im not worried about that.
Old 12-02-2004, 08:16 PM   #9
My Cold Air Intank Does It To But Sounds More Like A Blower. You Could Also Have A Vaccum Leak.
89'FIVE-O is offline   Reply With Quote
Sound Waves Car Show 2006 Dark02Pony Pictures and Videos 5 07-10-2006 07:15 PM
i want my car to sound like this *VID* Kyle The Bar 11 10-19-2005 02:56 PM
Video And Sound Of My Car mohrnormal The Bar 27 03-16-2005 02:09 PM
Video and Sound of my car. mohrnormal Pictures and Videos 2 03-13-2005 08:29 PM
New vid and sound clip of my car Testicleez The Bar 4 11-13-2003 05:56 PM
11:43 PM
