Which rear gear would you choose - Mustang Evolution
Old 11-16-2004, 05:37 PM   #1
Talking Which rear gear would you choose
I wondering what company makes the best rear gear for a 03 V6 mustang, but is also not too expensive.
coolstang is offline   Reply With Quote
Old 11-16-2004, 06:31 PM   #2
Fishers Stang's Avatar
4.10 W/ T lok. most pop, and price is about the same...
Charles
Old 11-16-2004, 06:37 PM   #3
you could go with richmond gears for about $160 or straight from ford racing for around $175. a t-lok would be a good investment as well. Auburn makes a nice one and ford racing has one for about $200.
bigpomps is offline   Reply With Quote
Old 11-16-2004, 08:06 PM   #4
do u have a manual or auto
if you have auto get 4.10
manual get 3.73
WWW.gefracing.com
Old 11-18-2004, 03:55 PM   #5
an 03 automatic
Old 11-18-2004, 03:58 PM   #6
if i get 4.10. I will be able to beat the guy on the line for a second, but then he would blow me away and 4.10's would hurt my gas mileage. This is why i want 3.73
Old 11-18-2004, 04:04 PM   #7
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
get 4.10s, they are good gear even after a 30 mph
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 11-18-2004, 04:24 PM   #8
Send a message via AIM to kaper232 Send a message via Yahoo to kaper232
http://store.summitracing.com/defaul...Ratio&x=12&y=8
http://store.summitracing.com/defaul...3.73%3A1+Ratio
kaper232 is offline   Reply With Quote
Old 11-21-2004, 12:30 PM   #9
I've got 4.10's from Motive Gear. Found them on eBay for $115 new.
They work perfect, no whinning, or setup problems. Installation cost me $100
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 11-21-2004, 06:48 PM   #10
01GTType's Avatar
Send a message via AIM to 01GTType
100. installation is hella good.. Looks like you got a good deal all the way around.
01GTType is offline   Reply With Quote
Old 11-21-2004, 07:00 PM   #11
slvr2000stang's Avatar
I have had 3.73's for two years.
I have 4.10's waiting to be installed. Go 4.10's
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-21-2004, 07:05 PM   #12
Ponycarman's Avatar
I've run 4.10's in the past. They are ok.
I've run 2.26, 2.45, 2.76. 2.94, 3.23, 3.55 and the 4.10's over the years in various cars. My favorite is the 2.94's. Just make some torque and you are good.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 11-22-2004, 09:36 AM   #13
They guy works for the local ford dealer in the service department, so he gets to borrow all the high speed tools and such to set it up. Took about 1.5 hours for the whole thing.
Old 11-22-2004, 09:40 AM   #14
oem ford parts are the only way to go on a rear end that wont see alot of power. The oem Ford gears arnt the problem its the tlock diff.. the spider gears are very weak 99.909090% of the time the tlok breaks far before the gears this failure of flying parts will take the gears after the fact.
www.speedconcepts.net buy a complete 8.8 if you have a pre 99 and be done with it for 725 vs 600~ or more to build the 7.5
Rear End Gear FAQ OsirisGuy General Mustang Discussion 18 11-10-2009 12:22 AM
Rear Gear Ratio natestang22 Pre-2005 V6 Mustang 2 07-20-2007 11:31 AM
Rear end gear!!!!!!!!!!!!!!!! coolstang Pre-2005 V6 Mustang 27 11-10-2004 12:56 AM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
rear gear and t-lok STEVE Pre-2005 V6 Mustang 40 05-28-2004 06:30 PM
11:38 AM
