clutch help - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 03-19-2009, 03:38 PM   #1
guerrerosal is unknown around these parts
Send a message via Yahoo to guerrerosal
clutch help
i am worried that theres something wrong. when i shift usually just second and third, its not smooth . is there something i can do about that ?
its a 2006 mustang 20000miles
guerrerosal is offline
Old 03-19-2009, 04:18 PM   #2
2007STANG's Avatar
2007STANG is unknown around these parts
Re: clutch help
That comes with it everyone I've Talked to says the same thing. They Make a short throw shifter
2007STANG is offline
Old 03-19-2009, 06:14 PM   #3
Terminator Owner
SpectorV is just getting started.
Re: clutch help
auto, manual, miles on car, etc?
SpectorV is offline
Old 03-21-2009, 06:24 PM   #4
Re: clutch help
it is manual with 18000 miles. should i change the tran fluid ?
Old 03-22-2009, 11:19 AM   #5
Terminator Owner
Re: clutch help
i personally like to change my manual trans fluid every year or two, its very easy, very cheap. You just need a little fluid pump to push it back in the trans OR take the shifter off and pour it in.
Buy mercon/dextron III ford trans fluid (check to make SURE you buy the right fluid in your car's manual) and then pour it in, it takes 3 quarts i think or a touch under.
take the drain plug and fill plug out and the fluid will drain, these are on the same side, cant remember which, they are easy to see. Put fluid in until it comes out of the fill plug, should be what should be put in it as this comes out then your done. The car being level is probably a good thing as well.
if your clutch petal is low to the floor and not very high this may be your problem, your not pushing it in far enough so its hard to shift since its not fully in neutral.
you can get under the dash push the clutch in with one hand and hold the clutch quadrant (located above the gas petal, half circle shaped with a little gear on the back of it. Ease the clutch out while you hold pressure aginst the quadrent tring to turn, you cant keep it from turning but you make the clutch thing its loose (this makes the cable have slack in it) so it will self adjust and you will hear a click very easy to hear. Click it a couple times you want a clutch petal thats firm at the top but you have a half inch of travel before the clutch starts to slip.
Go drive the car get up to 55mph and hold the gas constant push in on the clutch and you should be able to push it in at least half an inch (but not much more than this) and the rpms will jump up. This is the sweet spot. See if this helps you.
SpectorV is offline
Closed Thread
Need Clutch Help!!!! jkaminski24 1996-2004 Mustang GT 21 05-05-2010 08:43 AM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 11:54 AM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 03:04 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
Clutch Murph00 Pre-2005 V6 Mustang 2 06-30-2004 04:00 PM
03:10 PM
