1995 GT Rear End... Help please. - Mustang Evolution
Old 03-21-2009, 06:14 PM   #1
Ok I'm originally off of the moddedmustangs forum... nobody on there answered my question.
So here's my question...
Will a 1995 GT rear end bolt directly up in to my 1998 v6 without any modifications?
If there is any... please tell me what would need to be done to make it fit.
Thanks guys.
justinsstang is offline   Reply With Quote
Old 03-21-2009, 10:02 PM   #2
Re: 1995 GT Rear End... Help please.
The rear end will directly bolt up. Only thing I would worry about is problems with the driveshaft hooking up...should be an easy direct swap though.
Old 03-22-2009, 12:05 AM   #3
Ok thanks. If the driveshaft doesn't hook up what should I do then?
Old 03-22-2009, 07:05 AM   #4
Get the rear driveshaft U joint off a 95 GT lol. It most likely will bolt right up however.
Old 03-22-2009, 11:02 AM   #5
if yours has abs and the one you get the rear from doesnt you can swap your axles over as they are teh same (as far as i know) just fyi
Old 03-22-2009, 02:43 PM   #6
Ok, thanks alot guys.
Old 03-25-2009, 02:29 AM   #7
Ok so I decided against buying it... I had 2 ford mechanics, and two highly respected people around my area all say it wont work... the gt has an extra set of shocks on the top, and there's no place to hook it up on the v6's... so you'd have to run only one set, the norm on the v6. Doing that, the rearend will bounce up and when u get on it ur gonna be bustin u-joints.
That was the summary of their explanations to me.
GT Rear end fasternu_674 Pre-2005 V6 Mustang 11 01-21-2008 04:41 AM
Rear End megax29 Pre-2005 V6 Mustang 8 08-27-2007 07:19 PM
1995 cobra rear spring!!!! plainegreg Mustang Parts for Sale and Wanted 3 03-10-2007 10:39 AM
rear end v6stangracer Pre-2005 V6 Mustang 12 03-23-2005 09:41 AM
8.8 Rear End ttpancakes Mustang Parts for Sale and Wanted 8 07-20-2004 06:39 PM
03:14 PM
