Change you coolant regularly - Mustang Evolution
Old 11-20-2004, 07:41 AM   #1
.... i change mine every year and i just changed it for this winter and OMG you would be amazed at the white crap floating around in there from the aluminum.... so change that crap! it only takes 20 bucks and a little time.
Old 11-21-2004, 03:16 PM   #2
Do you think you could make a how to. I think i know how to do it but i want to make sure i don't screw something up.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 11-21-2004, 04:01 PM   #3
Fishers Stang's Avatar
haha my hose is leakin thats part of the reason my stangs parked be4 turky day, but yeah I need to change those and my coolant..
Charles
Old 11-21-2004, 04:33 PM   #4
Ponycarman's Avatar
A note on hoses. One of the hoses to the heater core has a flow restrictor in it. That restrictor is there to prevent the heater core from rupturing when spinning the enigine at high rpms. Ford's replacement hose and all the aftermarket ones I have looked at do not come with this restrictor. You can remove the restrictor from the old hose and put it in a new one, but do not reuse the crimp clamp.
I did and it failed to hold allowing the restrictor to turn sideways. This eventually caused my heater core to rupture. Yeah a new heater core is only $40, but replacing it entails removing the entire dash, disconnecting the AC lines and about $600 for labor at the dealer. I did it myself, but if you can't it'll be expensive and even if you can it's not quick.
I ended up replacing the restrictor with a 1/2" NPT pipe plug with a 1/4" hole drilled thru it. This plug was deep enough to allow me to use a worm gear hose clamp to keep it in place and it will not turn sideways even if the clamp fails. The restrictor goes in the supply to the core hose.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 11-22-2004, 11:54 AM   #5
Thanks for the info ...
Coolant refilling GTRAGTOP 1996-2004 Mustang GT 15 10-01-2009 05:49 AM
coolant problem......AGAIN!! NHStang03 1996-2004 Mustang GT 10 01-22-2009 05:07 AM
Well its winter time CHANGE your coolant SpectorV The Bar 11 11-22-2005 09:02 PM
Coolant Change 99v6TxStang Pre-2005 V6 Mustang 6 11-10-2004 06:10 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
10:38 AM
