Really Dumb Question *Newbie Warning* - Mustang Evolution
Old 07-24-2003, 11:18 PM   #1
Ok Ive had my car for almost a year and have been taking it to jiffy lube to get the oil changed because I have been short on time and the weather last winter was horrible. Now I've decided to start changing it on my own but I have never done this before and was looking for some help. I am thinking of going with Mobil 1 5w30 but what else do I need to buy other than a filter ? Any tips or advice would be greatly appreciated
98Blue232 is offline   Reply With Quote
Old 07-24-2003, 11:55 PM   #2
Monkey's Avatar
for the first time, a drain pan and a funnel. thats it though.
i would suggest 10w30 though instead of 5w30. just my opinion though.
all you do is remove the drain plug, let the oil drain. change filter, put darin plug back in, pour new oil in.
Old 07-25-2003, 06:58 AM   #3
if you cant find the oil plug, get a manual (haynes, chiltons etc...) they are very good for that type thing.
http://www.mustangmods.com/data/1581/sig3.jpg
Check out my car on cardomain!
CAI (99+), 17" 01' GT rims, Hankook hrII tires, interior switch pony, dressed up engine (blue), other numerous appearance mods
Sil\/erSpeed is offline   Reply With Quote
Old 07-25-2003, 10:20 AM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Ditto. For the simple jobs, Chiltons or Haynes manuals are great.
Rellik is offline   Reply With Quote
Old 07-25-2003, 02:27 PM   #5
Monkey's Avatar
heck, i still use mine when taking apart the engine or doing a drivetrain swap. they completly tore apart a car and it had a lot of good info in them
Old 07-25-2003, 08:27 PM   #6
Is that the Chilton or the Hayes that you are talking about monkey ?
Old 07-25-2003, 08:58 PM   #7
Monkey's Avatar
haynes
Old 07-26-2003, 08:23 AM   #8
I personally have a Chiltons. They're practically the same anyway. I think my Chiltons Manual cost about 13 bucks.
Old 07-27-2003, 02:13 PM   #9
fast64's Avatar
I filter wrench would be helpful also.
GO BRAVES
Old 07-29-2003, 09:49 PM   #10
Ill make a how to on this, lots of people ask this believe it or not, iam just waiting for my next change.
Old 07-29-2003, 10:24 PM   #11
Monkey's Avatar
a how-to on changing oil?
here you go.
1. jack front k-member up
2. unbolt drain plug
3. let oil drain in pan
4. remove oil filter
5. put new filter on
6. put drain plug back in
7. fill with 5qts of oil
8. start car and drive off into the sunset.
8)
Old 07-29-2003, 11:35 PM   #12
newb's like pics.
Old 07-30-2003, 12:25 AM   #13
Monkey's Avatar
Originally Posted by Smokedya95stang
newb's like pics.
haha okay.
Old 07-30-2003, 08:43 AM   #14
Send a message via AIM to el cheapo
you might wanna rub a little bit of fresh oil on the seal of the new filter when you screw it in, just to make sure the gasket is nice an moist. . . thats what ive always done.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 07-30-2003, 08:50 AM   #15
i always do what el cheapo said too.
Old 07-30-2003, 10:42 AM   #16
here you go.
8)
Ok, now take that a step further and give us the bolt sizes and TQ specs for the bolt and the filter. Examples of filter types and oil viscosities. Checking the oil on a regular basis. check the oil level after the fill up, and so on. What tools are needed and whre you cna pick everything up.
Old 07-30-2003, 11:41 AM   #17
Ill do it my next change which will be soon.
Old 07-30-2003, 04:40 PM   #18
What are you suppossed to put the old oil in ? Someone told me it was illeagal in some states now to put it in empty milk jugs and stuff
Chris
1998 V6 Auto
MAC CAI, GT Takeoffs, MAC Flowpaths, Clear Corners, Underdrive Pulley, 4.10's w/ traction lock, Steeda tranny cooler
Currently saving for the 2005 GT mod
Old 07-30-2003, 04:44 PM   #19
Ask your local auto store if they recycle oil, and the requirements for getting it there. they usually take it in the big re-usable oil tray containers. They empty it and give you the container back
Old 07-30-2003, 05:20 PM   #20
yea its illegal to dump that ####, but everyone does it anyway.
I put it in milk jugs, and stick it in a dumpster.
I also believe autozone recycles oil, so they take it free.
Old 07-30-2003, 11:23 PM   #21
Rick0636's Avatar
Correct on Auto Zone, I think Advance Auto is the same. I find a set of the plastic Rhino Ramps is a lot handier than jacking up the car, I feel safer too, and you don't even need jack stands. I have steel ramps, but mustangs tend to be so low they hit on the steel ramps and can damage things.
Old 07-31-2003, 11:24 AM   #22
Ok anyone now the model number on the filter that I need ? I went to autozone and there were like 50 different kinds and the only guy there was a complete moron
Chris
1998 V6 Auto
Old 07-31-2003, 11:36 AM   #23
Fram Extra Guard - PH3600
Fram Tough Guard - TG3600
Fram Double Guard - DG3600
Get the cheapest one
Old 07-31-2003, 12:51 PM   #24
tire's Avatar
Send a message via AIM to tire
most places charge a few bucks for taking oil.
however where i live they do it for almost free, and it makes oil changes worth doing yourself.
heck i will be changing my oil shortly as well, if i had a digital camera i'd shwo you how.
tire is offline   Reply With Quote
Old 07-31-2003, 12:59 PM   #25
Well I have a digital camera and am going to change it tommorow so I'll take pictures as I go along
Chris
1998 V6 Auto
Old 07-31-2003, 01:49 PM   #26
sounds good.
Old 08-01-2003, 10:03 PM   #27
Ok tried today and didn't have a very fun time. To start, the rhino ramps slid forward whenever I tried to drive up on them so I ended up having to jack up each wheel and cram the ramp under them. Then out of nowhere it decided to start raining so i had to move into the garage and repeat. Then I finaly get under there and I cannot get the freaking drain plug off. No matter how hard I tried, it wouldn't turn and then the socket would just keep slipping on the bolt. So I spent forever trying to get it off but nothing would do it. Eventually it was time to shower and go to work so I just gave up Any suggestions ?
Chris
1998 V6 Auto
Old 08-01-2003, 10:06 PM   #28
Take it to autozone ford whoever, get a new bolt you stripped it.
You'll have to pay for the oil change while your at it.
Old 08-01-2003, 10:19 PM   #29
Rick0636's Avatar
Question? Did you put the bolt in there? If you did, why did you tighten it so tight? If you had used a 6 point, as opposed to a 12 point socket you may have had a more successful time getting it out, I take it that you rounded the corners of the bolt off and that is why it won't turn now? Sears makes special sockets for messed up bolts which might do the job if this is the case.
Old 08-02-2003, 08:03 AM   #30
I've tried those sockets at sears they dont work so well.
Old 08-02-2003, 08:43 AM   #31
Well I haven't ever touched the bolt I think jiffy lube probably did something to it. I'm going to go back under my car monday and see if a little wd-40 and some luck won't help. The bolt looked a little rounded but it didnt look too major
Chris
1998 V6 Auto
Old 08-02-2003, 08:58 AM   #32
make sure to find the correct socket for it.
Old 08-02-2003, 10:09 AM   #33
If you strip the bolt, your next best option will be vise grip pliers. You will need to replace that bolt if it gets too rounded.
Also, Change your actual body possition if you cant get the bolt off. If you cant get it one way, move around to a different possition. You may not be getting the leverage that you may need due to your body mechanics (No, I'm not a body mechanist specialist, but I have worked for chriopractors for a while). Changing possitions may seem stupid, but that works for me a lot of the time.
Old 08-02-2003, 10:33 AM   #34
Vise grips usually just strip it more, trust me ive tried it.
Also get a breaker bar. Works wonders in these situations.
quick newbie question selfinfliction Pre-2005 V6 Mustang 6 05-25-2008 08:06 PM
erm, um....dumb question? ChickStang02 ME Site Help & Announcements 3 03-10-2007 08:56 PM
Dumb question.. cms09071987 Pre-2005 V6 Mustang 3 05-24-2005 09:46 PM
dumb question but just wondering V6Stang33 Pre-2005 V6 Mustang 3 02-23-2005 01:20 AM
this may be a dumb question but... 232SCstang Pre-2005 V6 Mustang 8 04-14-2004 12:25 PM
07:03 PM
