03-24-2009, 04:58 PM
#1 | | Senior Member
| Tri-Ax shifter
I bought one from Atomic Performance, would it also be wise to go ahead and pick up a shifter gasket while I'm at it?
03-25-2009, 02:35 AM
#2 | | Registered User
| Re: Tri-Ax shifter
for about 11 bucks you might as well... new gaskets never hurt, and it doesn't look like these are to expensive (the 11 bucks was off AM, free shipping...(i don't know if all shifter gaskets are the same though, this was all just my .02))
EDIT: Cmon delta, one more post to 100!!
It's cheaper to be beat a viper than to lose in one. 1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs). Quote: |
Originally Posted by sti2gsxr There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles. | |
03-25-2009, 07:59 AM
#3 | | Terminator Owner
| Re: Tri-Ax shifter
for the triax I would as its a more noisy shifter vs others. Also... while your screwing around and have the shifter off why not change the transmission fluid hmmm? you just pull the drain/fill plug and let it drain out then put the drain plug back in and fill it up via the transmission tunnel where the shifter was to factory specs put the fill plug in and your done
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
03-25-2009, 09:09 AM
#4 | | Senior Member
| Re: Tri-Ax shifter
Alright, I'll go ahead and order one while I'm at it. And thanks to Beaner for the discount code. I read your write up on how to change the tranny fluid, and thanks to you Spec.
03-25-2009, 12:23 PM
#5 | | Registered User
| Re: Tri-Ax shifter
i read that article as well and was able to get the car up enough to squeeze under it and do that, thats spec for the article, i think its to late for the tranny though
03-25-2009, 12:42 PM
#6 | | Senior Member
| Re: Tri-Ax shifter
I'll be using my friend's dad's hydrualic lift for that |
03-25-2009, 01:05 PM
#7 | | Registered User
| Re: Tri-Ax shifter Quote:
Originally Posted by 19Delta I'll be using my friend's dad's hydrualic lift for that  | your lucky, i get to do all my work out in my apartments parking lot, everyone stares at me funny when i'm working on my cars :S, but i wasn't going to pay some guy 50 bucks to take out 2 screws, sit there, put one back in, put 3-4ish quarts of oil in there, than put the other screw back in.
i only lifted the front and the body seemed to be sitting pretty level to the ground so i'm hoping it worked out ok, but it makes funny sounds still and from what i've discussed with others is that the synchros are going out
03-25-2009, 03:15 PM
#8 | | Terminator Owner
| Re: Tri-Ax shifter
you cant pour the fluid into the trans you have to use a pump thing or pour it in through the shifter hold when the shifter is out.
and there is a thanks button in my post, bottom right you can thank whom ever you want if you got good info from the post  just fyi
03-25-2009, 08:36 PM
#9 | | Registered User
| Re: Tri-Ax shifter
get the gasket
03-25-2009, 08:43 PM
#10 | | Registered User
Originally Posted by upton7 get the gasket | ^+1 Quote:
Originally Posted by SpectorV you cant pour the fluid into the trans you have to use a pump thing or pour it in through the shifter hold when the shifter is out.
and there is a thanks button in my post, bottom right you can thank whom ever you want if you got good info from the post  just fyi | i have tried giving thanks to a couple people that have really helped me out, all i get is a window full of text, it kinda looks like a java script error? :S i dunno for sure though
03-26-2009, 08:22 AM
#11 | | Terminator Owner
| Re: Tri-Ax shifter
hurm lol next time you get it screen shot it and PM brent or post it up in the correct section for the staff to look at.
