how much power can v6 handle - Mustang Evolution
Old 11-25-2004, 10:32 PM   #1
what is the maximum horsepower and torque that the stock internals on the 3.8l v6 safely handle before you need to start upgrading ?
jedwards242000 is offline   Reply With Quote
Old 11-25-2004, 10:45 PM   #2
97Stallion's Avatar
hmm, this is kinda a debatable question. Many people here have supercharged their V6 withstock internals if that's where you are heading with this question from your other post. The key to having long lasting internals is a good tune, I would definatey recommend Alberto for this. But to give you more of a solid answer I would say somewhere around 300-350hp would be safe. But remember, it's always to be safe that sorry.
Living one day at a time!
Old 11-26-2004, 08:53 AM   #3
Ponycarman's Avatar
Good tune AND good maintenance. Regular oil changes, plug checks/replacements, etc. A power adder will magnify poor maintenance issues.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 11-26-2004, 11:03 AM   #4
99+ i wouldnt push more than 11psi from a blower on it in stock form.
Old 11-26-2004, 04:02 PM   #5
a the stock internals can handle a fair amount of power but there would need to be a lot of fuel managment and spark upgrades. like new injectors, fuel pump, new spark plugs, wires, and even a new cam and heads will help the life of the stock internals. If the set up is there then you could run about 14psi on a blower and a good 50 shot of nitrous. so maybe around 400-430rwhp. on stock internals for a v6. my friend has a 2001 v6 and is runing 13 psi on stock internals with a procharger and 30 shot of nitrous. his car has 45,000 miles on it. It's not recomended to do it for a long time though, thats why he's getting forged wiseco pistons and rods, with moly rings. if you don't want to risk the stock internals, dish out about $1500 and get the forged internals, its worth the money if your serious about the massive amount of hp. BTW, my friend also has a 2000 gt rear end with 3.73 gears which also is good to have with that much torque. Your rear end will probably go before your engine will. good luck.
bigpomps is offline   Reply With Quote
Old 11-26-2004, 04:21 PM   #6
pretty much the stock everything on a 99+ is fine until you start to rearch the 325rwhp level then they begin to need replacing. I would say after 320rwhp~ upgrade some items but the spark even then would probably be fine.
Old 11-26-2004, 05:47 PM   #7
Another major factor is the tune... you can blow up a car with 8 psi 10 times faster than one with 11 or heck even 15 if the tune is very good... the little pos chips they send you are wrothless ONLY have a real dynotune done someone who knows what they are doing... and those are few and far between.
Old 11-26-2004, 06:20 PM   #8
You can buy crate engines for the 3.8 Liter V6 and the 4.2 Liter at redlined performance. the web address is www.rpm_mustangs.com. These engines can handle up to 11 psi and possibly more with the upgrade options. This is where I'm going to order my mustang engine from. Currently my car has 132,000+ miles on it but it uses
no oil and doesn't smoke.But adding a supercharger or NOS to might make the engine
give up compression or worse spit a rod out. That's why I'm getting a new engine
with some of the upgrade options. these engines can make 350 to 450 horsepower
without any worries.That is with a supercharger or turbocharger.Check it out.
witenightmare97 is offline   Reply With Quote
Old 11-26-2004, 06:22 PM   #9
Also the stock headers can handle up to 300 horsepower.But its best to go with an aftermarket header system.
Old 11-27-2004, 07:02 PM   #10
thanks for all th input guys
Old 11-29-2004, 07:15 PM   #11
Kiljosh's Avatar
Go with longtubes if you don't have to worry about emissions...if you do than shorties are your ticket. On 94-98 the Shorties make minimal gains until around 300hp(? or 250, i forget) but 99+ have ugly *** headers and they could use the help. Both help the sound but I'd trade my shorties for longtubes anyday of the week...
Old 12-04-2004, 03:31 PM   #12
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
99+ have manifolds not headers
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 12-04-2004, 06:58 PM   #13
Send a message via AIM to kaper232 Send a message via Yahoo to kaper232
kaper232 is offline   Reply With Quote
Old 12-06-2004, 05:42 AM   #14
Most of these posts are worthless.
A good tune is very important. Chips are not POS...depending on where you get them.
My bone stock 3.8 did just fine at 300rwhp.
My 4.2s have lived past 350rwhp. The last one made 465rwhp.
The stock stuff is better than most people know.
http://www.fordchip.com
Featuring Superchips Custom Tuning products
'99 4.2L 5-spd, Powerdyne, CNC'd heads, 211/.523 cam, 70mm TB, 1.8 RRs, JBA headers, custom X off-road, 90mm SCT, 60#s, Mach I duals, Ripper, PHP 8.8, Steeda UCAs, LCAs, 3.73s, Alum driveshaft, 245/45R17s on Silver Bullitts
11.3 @ 122 (ET Streets)
465 rwhp/460 ft/lbs (25hp dry shot)
12/00 MM & FFs, 7/01 5.0 & Super Ford, 2/02 Hot Rod
pete is offline   Reply With Quote
Old 12-06-2004, 06:44 AM   #15
Old 12-06-2004, 06:55 AM   #16
Danger Dude's Avatar
BINGO. Pete hit it right on the head. The stock motor is quite capable with a good tune. A lot of people waste money modding with stuff they see advertisements in magazines. Dont waste your time playing the Ricer Math Manufacturers Claims game it just does not add up.
Chips are not a POS. I am not sure where that came from. When modding a car it sometimes takes a couple of tunes to get it right, but I will also agree a dyno tune is prefered. I know many people who are happy with their Fordchips and SCT chips. Pete did me right. Hell I had problems but they ended up being my cats being clogged and not the programming!!!
Old 12-06-2004, 01:51 PM   #17
the chip that comes with the 11psi procharger kit is a diablo. when he got it he was only getting about 275 hp at the wheels. then i heard that the chip that comes with that particular kit was crap so we went with SCT, cause its made by ford, and after we got the chip from them he was making over 350 at the wheels. some difference a good chip/tune can do to a car. he was also running more boost after the tune as well with only one step smaller pulley.
Can the Stang handle it? blue-saleen Mustang Audio & Video 7 03-19-2010 09:25 PM
How you handle a Heckler bluemustang Pictures and Videos 8 12-02-2006 12:32 PM
Which Shift Handle PureVenom Mustang Audio & Video 42 11-20-2006 07:56 AM
New eBrake handle. Dom Mustang Audio & Video 2 05-06-2004 12:52 PM
Cant handle this! Tbird232ci Mustang Audio & Video 1 05-02-2004 08:23 PM
10:46 PM
