Super and Turbo chargers together. - Mustang Evolution
Old 07-25-2003, 12:21 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
This is so weird. Last night I went to a truck pull. The winning semi truck won and the announcer said he had "twin turbos feeding the stock supercharger." I really never figured it was even possible to run both... How could that work?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-25-2003, 12:27 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Run the boost produced from the T/C's into the S/C intake. I've seen it done before... but I dont really understand why you would want to much boost
Rellik is offline   Reply With Quote
Old 07-25-2003, 01:04 PM   #3
Region: Iowa
Wow... Just wow. It was pretty unbelieveable to listen to. And it pulled like you wouldn't believe.
Old 07-25-2003, 01:33 PM   #4
I wouldnt doubt it... with 30+ PSI of air being crammed into theose clynders!!!
Old 07-25-2003, 02:25 PM   #5
Monkey's Avatar
also, you could get small turbos to combat the top end of the supercharger. that way there is no boost lag for either blower or turbo. and like rellik said, just have the turbos run off into the air intake for the blower.
Old 07-29-2003, 02:56 PM   #6
dapack69's Avatar
Send a message via Yahoo to dapack69
You have to remember though. Those are Diesel engines, there made to tolerate a lot more.
dapack69 is offline   Reply With Quote
Old 07-29-2003, 03:05 PM   #7
Send a message via AIM to el cheapo
yeah most Diesels my dad works on run at least 20 psi turboed and alot run 30+ its not uncommon.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 11-21-2003, 07:31 PM   #8
Dom
Dom's Avatar
Send a message via AIM to Dom
You gotta remember too, disels had turbos way before people in Civics even thought about them.
If you wondering how it works, you wallet is about 12 inches thick. Thats how.
Old 11-21-2003, 08:53 PM   #9
tire's Avatar
Send a message via AIM to tire
I've seen a TT/SC combo before and I've seen some online before... they are more show than go, and Horse's semi apparently had enough go though... I'll did up a picture of a car with such a setup, but there would be more than one way to do it anyways. Seems like a big waste of money to me!
EDIT - You don't need more than one supercharger or turbo to make 30+ psi, just a larger blower.
tire is offline   Reply With Quote
Old 11-25-2003, 11:07 AM   #10
super chargers have no lag.. maybe you mean the supercharger would make up for the lag of a BIG turbo
hopeing i get this black on grey 96 5 speed sixxer
but i already have a 87 5.0 coupe, and a 94 regal for my daily beater(until i get the black car *wish me luck*)
notav8 is offline   Reply With Quote
Old 12-21-2003, 12:56 AM   #11
Ponycarman's Avatar
The supercharger takes the compressed air from the turbos and compresses it even more to get 50+ psi of boost.
More boost = more power, till things go boom.
I once ran 25+ psi of boost in my otherwise stock 2.5L 4 banger once, I forgot to hook up the wastegate line after putting in a new turbo. Fragged a rod bearing
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 12-21-2003, 02:16 AM   #12
tire's Avatar
cent. s/c's don't make power without high rpms, not lag but little bottom end power! a roots blower/large turbo would be "ideal" i would think for this silly thread and idea of more than one power adder.
Old 12-21-2003, 06:49 PM   #13
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
wow i would be happy with just an sc... i guess some people have money to waste
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 12-21-2003, 10:37 PM   #14
Dom
Dom's Avatar
My dad works at the shiping yard for 18 wheelers...he was talkin about when one of the trucks were commin in, the S/C blew up. :no:
turbo chargers roush727 General Mustang Discussion 3 03-07-2010 03:48 PM
Post Pics of Your Turbo, Super, and N2O set ups... DarkShadow General Mustang Discussion 54 02-09-2009 02:15 AM
Turbo or super charger??? Mustangbobby General Mustang Discussion 3 05-11-2008 12:25 AM
V6 Turbo vs. Super fasternu_674 Pre-2005 V6 Mustang 17 10-14-2007 05:30 PM
04:44 PM
