Car won't start - Mustang Evolution
Old 11-30-2004, 11:20 AM   #1
V6STANG007's Avatar
Send a message via AIM to V6STANG007 Send a message via Yahoo to V6STANG007
Car won't start
over the last couple of weeks my car has been giving me problems starting. to be more specific, It would not start. I kept on thinking I had to go by a new battery. well today my car is dead. So I am going to get a new battery. My questions are: What brand battery u guys recomend, and should I get something else. I know I probably need to change the spark plugs. They've been there for 66000 miles. How do I know all I need is a new battery and not have any other problems (ie:starter)? the only way my car will start is if if someone gives me a jump start, and then when I turn it off, it won't start again.
please help!!
Thanks
Jorge ~
Originally Posted by Danger Dude
OK you are right!!! Maybe I am the Old Crazy One
V6STANG007 is offline   Reply With Quote
Old 11-30-2004, 11:47 AM   #2
Once you get is started can you unhook the battery and the car continue to run? If so, it's the battery, if not..it's the alternator. From what you are describing it's probably a little bit of both. But mostly the battery if it won't hold a charge
Old 11-30-2004, 11:53 AM   #3
V6STANG007's Avatar
It continues to run. I got to work today after jump starting it. but whe i got here. I turned it off, tried to start it again and it was dead.
Jorge ~
Old 11-30-2004, 11:54 AM   #4
It's your battery then. Put a new battery in the thing and see how it does. If nothing else, pull a battery out of someone else's car and then start your car with that. If you have an amp meter you can check and make sure your amp is able to charge a battery, I'm not exactly sure what the charge should be..but I'm sure someone on here knows. I'd go get a reading from mine..but it's pouring down rain here
Old 11-30-2004, 12:30 PM   #5
Yea it sounds like your battery. if you can get it to Autozone or a place like that they can test it out for you free.
Old 11-30-2004, 12:52 PM   #6
Danger Dude's Avatar
I would go to Auto Zone and have it checked like Brent said then Go to Walmart and get a Everstart Battery model # 58-3N (the model for Mustangs) for $40,00. They are really good batteries and with a great warranty (2 years free replacement no prorate)and good cranking amps for extreme cold or hot weather.
Old 11-30-2004, 01:14 PM   #7
V6STANG007's Avatar
Sounds good,
thanks guys. I'll change the battery and hopefully won't have anymore problems
Jorge ~
Old 11-30-2004, 07:58 PM   #8
V6STANG007's Avatar
OK, so I got the new battery, put it in and the car won't start. I'm like WTF!, so guess what ; u know that loop thing that conects the wire to the battery? it is broken . I did not see it when I put the battery in 'caus it is so damm dark outside. Anyway. I'm guessing that is what is causing no power to go through. will have to go in the morning to get one of those loopythingys (whatever they are called) ,Any tips on how to change that.can't be too complicated.
Jorge ~
Old 11-30-2004, 08:09 PM   #9
jimmy_beaner's Avatar
Region: Iowa
is there just some kind of screw holding a bunch of wires to it? It can't be that easy... I'll just start out by saying, I have no idea.... and I'm going to leave it to someone that knows a lot more than me
Old 11-30-2004, 08:11 PM   #10
Are you talking about the fuseable link wire ???????
Old 11-30-2004, 08:28 PM   #11
V6STANG007's Avatar
lol dude I do not know what I'm talking about. here:
(and I know it is dirty. I was going to clean it)
Jorge ~
Old 11-30-2004, 08:33 PM   #12
That would be why your car isnt starting
Old 11-30-2004, 08:33 PM   #13
Hell your battery terminal clamp is fried !!!!
Old 11-30-2004, 08:39 PM   #14
V6STANG007's Avatar
haha, thanks. that is what I said my terminal loopy clamp thingy is fried. now how do I change it. lol
And another question: should i keep the new battery?
Jorge ~
Old 11-30-2004, 08:41 PM   #15
Change it out first and see if you car starts fine with the old battery. I'm pretty sure your old battery is fine.
Old 11-30-2004, 08:44 PM   #16
V6STANG007's Avatar
If I don't get at least a hint on how to do this. I'm just going to cut the wires and put them back together with electrical tape
Jorge ~
Old 11-30-2004, 08:45 PM   #17
SilverStang96's Avatar
Send a message via AIM to SilverStang96
Since you already went through the trouble of buying a new battery, i would keep it... but that is up to you. Secondly, You should just be able to take the clamp off and put the new one back on there.
SilverStang96 is offline   Reply With Quote
Old 11-30-2004, 08:47 PM   #18
Have you tried taking the nut off the bottom of the bolt???
Old 11-30-2004, 08:49 PM   #19
I think you have to buy the whole cable.... autozone would sell it or any autoparts store. Just tll them what happened and they will tell you what you need
Old 11-30-2004, 08:49 PM   #20
01mineralgrey6's Avatar
youll have to cut the old clamp off the wire. strip back the insulation, and install the new clamp.depends on the kind you get, you can get some you have to solder on, some that crimp on, and then some that just bolt on.you can get them at wal mart for like $2
-Tony
'99 cobra 'vert
Old 11-30-2004, 08:49 PM   #21
crimping that gauage wire wouldnt be fun.. I suggest the bolt lol
Old 11-30-2004, 08:50 PM   #22
V6STANG007's Avatar
that's what I thought. Ithought by removing the bolt, I could remove the clamp, but the bolt is stuck in there.
*oh yeah just an FYI Corey, the model for the Everstart battery was 58-3s, but your post was most helpful, didn't have to look around much.
Jorge ~
Old 11-30-2004, 08:54 PM   #23
V6STANG007's Avatar
ok then, cutting the clamp off the wire it is, and make sure its the kind u bolt on, thanks a lot guys.
Jorge ~
Old 11-30-2004, 09:01 PM   #24
Yeah thats the way i had to do mine, when i was installing my system mine broke... I went to walmart bought one, cut the wires, strip the ins. off, twisted them where they would be tight, and then clamped the wires in the terminal.. presto.
Old 11-30-2004, 09:05 PM   #25
Let us know if it works out.
Old 11-30-2004, 09:38 PM   #26
Might be different between S and N is the year of the car Who knows !!
Old 11-30-2004, 10:35 PM   #27
i was told its North and South i don't know our books at work say N, but the batteries themselves say S who knows
-Tony
'99 cobra 'vert
Old 12-04-2004, 06:33 AM   #28
V6STANG007's Avatar
it's alive! it's alive. lol.
I'm keeping the new battery. I also bought some autolite plugs, I'll get those done as soon as I have some time. For now, Im happy I can drive my car. The insulation would not go back exactly the way it was. Is it ok if I enforce it with electrical tape? I could not find anything else.
Jorge ~
Old 12-05-2004, 10:37 PM   #29
Perfectly fine..
Old 12-06-2004, 07:08 AM   #30
V6STANG007's Avatar
:d
Jorge ~
Old 12-07-2004, 05:59 PM   #31
MonteCitan's Avatar
that test works great for older cars, but in newer cars it can cause a voltage spike that can fry the processor, I've seen it happen, and I've seen warning labels on many different publications saying the same thing..
as for spark plugs at 66k, you should be fine for a while longer, but it can't hurt to change the plugs
Old 12-07-2004, 06:07 PM   #32
O...didn't know that lol. Most of the cars I work on are mid-90's and older lol
Car won't start? Dude87 1996-2004 Mustang GT 16 10-13-2008 11:32 AM
Car Won't Start joseandmarilyn 1979-1995 Mustang GT 11 02-18-2008 12:22 PM
Car won't start Torchred02 1996-2004 Mustang GT 9 02-18-2007 01:17 PM
SO you expect to start your car up... PureVenom Pictures and Videos 17 01-31-2007 02:31 PM
Should I start modding this car? mustang99vert Pre-2005 V6 Mustang 3 10-24-2004 09:50 PM
06:06 PM
