2000 v6 mustang hood - Mustang Evolution
Old 03-28-2009, 05:01 PM   #1
Exclamation 2000 v6 mustang hood
Hi guys just got my first stang and wanted to know a little info. its a v6 2000. and im looking to get the roush kit for it. so i need this hood if you guys have a website wher i can buy this from it will help alot.
thanks
aj_198821 is offline   Reply With Quote
Old 03-28-2009, 06:05 PM   #2
Re: 2000 v6 mustang hood
You have the hood, all you need is the hood scoop.
I had roush parts on my last mustang and stage3motorsports is awesome.
Old 03-28-2009, 06:42 PM   #3
upton7's Avatar
ya yours doesn't have the raised hood scoop you can buy it off ebay or USA AND  CANADA it's just taped on i think someone correct me if i'm wrong
Old 03-28-2009, 08:04 PM   #4
thanks guys so all i need would be a scoope like this one right
99-04 Mustang OE Replica Hood Scoop
Fits OEM GT/V6 Hood Scoop- - PAINTED
The Mustang O.E. Factory Replica Hood Scoop Fits V6 & V8 Models That Did Not Come With The Factory Raised GT Scoop. Also Fits On Most 1999-2000 V6 & V8 Models That Have The Built In Lower Scoop. This Scoop Sits Atop The Existing Scoop Built Into Ford Mustang Hoods. Comes primed. Included scoop, grill, 3M tape, stainless steel mounting screws, Installation instructions and install template. Can be installed with just 3M tape but using the screws is highly recommended. Made from high quality solid core urethane. Made in the USA.
Reg. Price: $299.99
OUR PRICE $279.99
Shipping Included in Price above
Lower 48 States
Cost alot for a scoop but hey looks alot better and is it hard to put on or is it a peice of cake?
Old 03-28-2009, 09:20 PM   #5
You can definitely find it cheaper. I bought one for under 50 bucks and had it painted for 20 bucks. Installed using hardware from Lowe's and a homemade template.
As far as a template, when you get a hood scoop in take a piece of cardboard and cut it out to the exact size (as if it was sitting on the piece of cardboard). Mark the mounting points and lay this on the hood until you get it in the desired position.
- note - I do not believe the 2000 came with the rear holes preformed in the bottom of the hood - you will need to cut part of the inner hood support in order to attach the rear hardware
Once you get the template where you want it use the marking you had for alignment pins and mounting bolts and drill and clean these holes using the template. If you did everything correctly it should pop right in...
Old 03-28-2009, 10:52 PM   #6
i c i c.....thanks alot man....so this is my current car so all i gotta do is put the scoop on top of the old one right...
will it just fit right on ther? and i just gotta drill some holes with a template and then put the real thing on right
v6 mustang
2000 Mustang GT - Stock Hood Modification thesauceguru 1996-2004 Mustang GT 7 03-11-2009 11:58 PM
FEELER: WTT 04 cobra hood for cowl hood SimplyOrange Mustang Parts for Sale and Wanted 18 08-16-2008 05:13 PM
'02 Black Mustang Hood w/ GT Hood Scoop mattstang Mustang Parts for Sale and Wanted 8 08-22-2006 09:11 AM
Wtb Hood Scoop For My 2000 Black Mustang Cajun JungleBoy Mustang Parts for Sale and Wanted 15 07-24-2006 10:20 AM
REQ: 2000+ Stock hood with louvers ASSEMbler The Bar 10 01-08-2004 09:24 PM
11:46 AM
