Anyone know the weight of a SPEC Aluminum flywheel? - Mustang Evolution
Old 03-30-2009, 02:38 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I've searched and found that the stocker is about 25lbs, but I can't find out how much of a difference the SPEC flywheel is. I don't want to go too light and mess with normal drive-ability but I can't find anywhere on SPEC's website or elsewhere that lists a weight for it.
Thanks in advance
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-30-2009, 02:50 PM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: Anyone know the weight of a SPEC Aluminum flywheel?
Amazon.com: SPEC (SF84A MUSTANG) Aluminum Flywheels - Cobra, MACH 4.6L: Your Store
says 30 lbs... i think thats for the cobra... but it might be the gt's... didn't know what your car was, that was really the only thing i could find
EDIT: i looked up the ones for the gt and the v6, only place that gives a weight is amazon, so i doubt its that reliable, but all 3 are 30 lbs says them
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 03-30-2009, 02:54 PM   #3
Region: Oregon
Add to Cart
says 16 lbs on the v6 flywheel, i started searching the product id "SF83A" dunno if that helps
Old 03-30-2009, 04:42 PM   #4
Region: Iowa
That helps a ton, thanks. It never dawned on me to check Amazon for car parts. I just googled and searched the sponsor sites.
Old 03-30-2009, 07:57 PM   #5
Region: Oregon
me either, i was scanning the content in the search from google and that was the first one with a weight, i think the second one was more accurate, i don't think an aftermarket flywheel would weigh more... :S
Old 04-02-2009, 12:05 PM   #6
RyansQuick6's Avatar
MIne feels like it weighs about half of what the stocker did, but I never put it on a scale to know for sure.
RyansQuick6 is offline   Reply With Quote
SPEC Flywheel, pressure plate, disk and bearings Foxone Mustang Parts for Sale and Wanted 1 07-19-2010 05:36 PM
flywheel bolts 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:47 AM
79-93 Be Cool Aluminum 2-row radiator w/ aluminum cap fast64 Mustang Parts for Sale and Wanted 6 07-22-2009 02:14 PM
looking for a flywheel cjd10 The Bar 2 03-20-2005 04:19 PM
Aluminum Flywheel (dont hurt me) mheath Pre-2005 V6 Mustang 2 07-15-2003 10:40 PM
11:12 AM
