Best RPM range to stay in for acceleration - Mustang Evolution
Old 04-01-2009, 03:42 PM   #1
stangaroo's Avatar
My rev limiter is at 6,450rpm right now and when I red line it I up shift at about 4100rpm which is about 500rpm after the peak torque... is it better to shift sooner and upshift to 3500 (peak torque) or is it better to take it all the way through each gear? And when I say better I mean fastest acceleration possible...
stangaroo is offline   Reply With Quote
Old 04-01-2009, 08:49 PM   #2
1234's Avatar
Re: Best RPM range to stay in for acceleration
I shift at 5000 to 5200 rpms. From what i understand that is best for v6's as well.
Old 04-01-2009, 10:02 PM   #3
stangaroo's Avatar
Interesting, hey how do you "thank" people on here, lol
Old 04-01-2009, 10:38 PM   #4
There's a thanks button in the bottom right hand corner of the post you want to thank, click it.
19Delta is offline   Reply With Quote
Old 04-02-2009, 04:48 AM   #5
bbunt302's Avatar
You want to shift more at peak horsepower rather than peak torque. Peak horsepower for the V6 is at 5250 RPM. So I would say just past that, like about 5300 RPM.
Scary stuff.
Old 04-02-2009, 09:15 AM   #6
Yea peak horse power and redline are two different things. You should NEVER take your car to the actual redline unless its peak power is there... which it shouldnt be.
The only time you should ever go past your peak power is if you want the rpms to be a little higher in the next gear~ but its a trade off.
Peak hp for 99-00 v6's is 5250 and for 01-04 is 5500 rpms (due to IMRC intake vales added). Shift there.
Do NOT go to 6400 rpms, i have no idea how you even got there as the car cuts off at 6,000 rpms from the factory, valve float can take place at 6200rpms on the v6's so do NOT go that high.
Old 04-02-2009, 12:25 PM   #7
stangaroo's Avatar
I think the 08 peaks at 5250 also, so revving past that doesn't help acceleration? I can only get to 6400 because I raised the rev limiter... I'll take it back to stock today, don't want to abuse the thing...
Old 04-18-2009, 07:24 PM   #8
97Stallion's Avatar
Actually the best way to see when you should be shifting is have your car dyno'd and with those results you'll be able to see where your peak HP and TQ is. TQ is pretty much irrelavent, but it'll still be nice to see it.
Living one day at a time!
RPM range problems - Updated with error codes ballajb 1979-1995 Mustang GT 20 03-25-2010 05:07 PM
Teh Range! Brent Pictures and Videos 15 03-24-2008 08:59 AM
Would you stay...or would you go? PureVenom Pictures and Videos 19 11-29-2006 11:25 PM
Wireless range Q WhiteStang99 The Bar 21 08-28-2005 08:58 AM
Looking for power but I want to stay NA cms09071987 Pre-2005 V6 Mustang 18 06-03-2005 10:57 AM
02:02 AM
