Is it possible to drift an automatic? - Mustang Evolution
Old 04-02-2009, 08:18 AM   #1
I have a 2000 v6 mustang automatic transmission. Is it possible to drift it? If so, how?
BMustang1 is offline   Reply With Quote
Old 04-02-2009, 08:43 AM   #2
Re: Is it possible to drift an automatic?
it all depends on the tires if they allow traction to be broke or not, you wont really have that much power so not 100% sure how it will work
<public announcement warning>
Please dont do that stupid stuff on public streets
Old 04-02-2009, 08:51 AM   #3
hottcobra's Avatar
it could be done with an auto, but you'll never have the torque to do it with a V6
Old 04-02-2009, 08:52 AM   #4
Not to mention the open diff will not help your drifting out at all...
Old 04-02-2009, 08:54 AM   #5
hottcobra's Avatar
another good point.
by the way. I lover the bottom of your sig
Old 04-02-2009, 08:54 AM   #6
Herbstang's Avatar
You could drift with an automatic transmission but you'd have a lot less control than you could with a manual.
What if half way around a corner it decides to shift? Using an auto not only eliminates many techniques used to initiate a drift, but puts you at the mercy of the transmission. It doesn't know the difference between going up a steep hill and sliding around a turn.
Old 04-02-2009, 08:55 AM   #7
He was stalking me again yesterday searching for my posts specifically...so I figured I would at least say hi.
Old 04-02-2009, 08:57 AM   #8
hottcobra's Avatar
how did you find out this info
Old 04-02-2009, 11:20 AM   #9
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
technically right before started it you could shift it into a gear and that way its locked in that one gear, but hitting that gear perfect would be hard in an auto imo.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 04-09-2009, 12:00 AM   #10
lock first gear.. get up to 4000 rpm while going in wide circles, release gas pedal for a sec or two, and then push it to the floor and turn wheel to the opposite direction.. it requires you to feel the right moment and steer it just right, but its very possible. i driftet my transmission to death tho. (i drifted an auto v6 un locked) dont ever try it on public roads. 1.) you dont know how and you will 100% crush into something (i hope it wont be people if you do try it in town.)/
2.) even while training in a lot or something make sure you have ALOT of room for error. i drifted of course like 7 times when i just started learning how.
drifting can be very fun. it makes you a better driver and improves your driving reflexes such as looking at the place you want to get to instead of the place the car wants to. but its dangerous, it ruins your car, and is quite costly overall.
to make it abit easier to drift, fill tires up to 50-60 psi and loose all the weight you can of the car. even the spare wheel.
6opka is offline   Reply With Quote
Old 04-09-2009, 11:18 AM   #11
runvsofthisbull's Avatar
Ohh its possible....just wait for it to rain....lol
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 04-09-2009, 10:29 PM   #12
or you could also try this trick:
hehe.. i got a buddy who did this.. and hes drifting a Daihatsu shermant 40hp.. its allways raining for him
Old 04-10-2009, 06:56 AM   #13
DarkShadows's Avatar
well drifting a auto v6 stang is possable and i have seen it before at the last drift event. ebrake and lots of gas.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 04-10-2009, 07:39 AM   #14
i didnt use no e brake.. i dont think you even should.. just weight transfer ,throttle control and steering just right.
Old 04-10-2009, 10:45 AM   #15
ok well then ill just forget what the drifting people taught me and everyone else then . While at higher speed usually the e brake is good to break the rear loose in a controlled manner. i dont mean leave the damn thing on but it is good to use to start the drift especially in a car that is prone to understeer.
Old 04-10-2009, 10:40 PM   #16
e braking causes more of a powerslide than a drift... you dont need 10000 hp to drift, you just need to get a good feeling of the car and know the moment she's gonna brake loose. and gentle steering. in 8 out of 10 of my first times drifting i either didnt slide at all or i would spin around my self.. i'm being tutoured by one of the best if not the best drifter around here, and he pointed out the things i did wrong.
a.I didnt give it enough revs entering the drift. result: no drift, just noise.
b.I hammered the gas to late. result: wee bit tail slide and then i understeered till i was in the sand. the tip he gave me: look at where you want to be, not at where the car is going.
c. same thing as earlier but this time i looked at where i wanted to end up and i did end up there instead of in the sand.
d.this time i gave it all, 4000++ rpm when i enter, leave the gas completly, weight shifts to the right, hammer the gas, the car throws its tail out, i start steering to the right the car got grip again, i end up in the sand... this time he told me i steered to fast to the right.. i should be gentler..
e. next try same result
f. this time i made half a turn drifting but i let go of the gas pedal resulting in grip and the end of a short drift..
g. same thing
h. i do half the turn + some..
and so on till i got it..
you gotta get a feel of your car and its limits.. i do full roundabouts atm and started learning how to shift directions...
Old 04-11-2009, 08:01 AM   #17
While i agree with most of your statement i dissagree with above. if you pull the ebrake it doesnt introduce a "powerslide". you use the ebrake to start the drift only then use throttle modulation and wheel control afterward. a "powerslide" would be the rear coming out due to too much throttle, and usually when the car is in some form of turning.
Old 04-16-2009, 05:49 AM   #18
i use the ebrake to "drift" my vw golf fwd.. if you watch the drift bible he also states its the easiest way, and that he learned how to drift starting with the e brake but then again he never uses it today except on u turns and such..
Old 04-16-2009, 07:25 AM   #19
FWD ebrake drifts are fun arnt they i didnt need the ebrake on my gti to get sideways cause i had the damn thing so stiff.
Old 04-17-2009, 09:22 AM   #20
Titus Wadicus
svtlx's Avatar
im trying so hard to get use to this whole drifting craze. where im from loss of grip is generaly a bad thing...lol. so do you have to get special drift tires for this stuff or do you throw on a set of junk tires and make the car do twisties?
Old 04-17-2009, 09:30 AM   #21
SaleenFiend's Avatar
The only drift I am interested in is the period when i release the gas after the 1/4 mile mark... I just drift on into the exit lanes.
Old 04-17-2009, 09:34 AM   #22
Titus Wadicus
svtlx's Avatar
dats wasup!!!
Old 04-17-2009, 09:38 AM   #23
More to life than going straight.
Old 04-17-2009, 09:39 AM   #24
they do make tires for specificly drifting but realisticl all you need are some ok rear tires and good fronts and your on.
Old 04-17-2009, 09:41 AM   #25
Titus Wadicus
svtlx's Avatar
i agree, but my car is set-up to hook, not to mention i dont have the tire budget. but i can appreciate the sport and the skill associated with it. im not a hater... just old school i guesse.
Old 04-17-2009, 10:15 AM   #26
Yes, I forgot, Going straight with a sideways car...
lol, I'm just joking on you! I think its neat and a fun fun sport!
Old 04-17-2009, 01:33 PM   #27
well i dont drift much either. i do mostly road racing and autox with the stang
Old 04-17-2009, 05:12 PM   #28
Titus Wadicus
svtlx's Avatar
i hear the term drift and all i can see in my mind are crushed quarter panels...lol
Old 04-17-2009, 07:21 PM   #29
i here the term drift and i see mismatched body panels and tie straps
Old 04-18-2009, 04:04 AM   #30
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
well i'm no expert but i have some fuzion tires on my stang and they are the best i have ever had. they will hook decent goin straight, they will hold the road real nice on corners, and they are awesome for drifting. they are extremely predictable and they dont lose too much rubber either. but i got mine used all 4 for only 175. bout 80% tread. totally affordable.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 04-18-2009, 02:39 PM   #31
Fuzion ZRis are the loudest ROAD NOISE tires I have ever driven on in a Mustang.
Old 04-18-2009, 05:38 PM   #32
Fusions are a good budget tire that's about it.
Old 05-03-2009, 09:58 AM   #33
why must you play with me standard is better in competition on any level i have a shift kit on my 83chevy caprice 700r4 my v6mustang kicks that chevy's *** all day stock manual not to mention every thing on the car is edelbrock and a mallory ignition system and cd ignition box seriosly your gonna need a lot of bondo on your mustang like crushed quarter panel guy! stick to the off ramp and out of my way
dalltx is offline   Reply With Quote
Old 05-03-2009, 10:03 AM   #34
yeah well ulike your quote looks like your legalizing those mexicans and not your marijuana although they come with it and sell it to you
in any case that trans needs a shift kit get one after you rebiuld it for better performance its like what 2 onces of pot
Old 05-04-2009, 02:33 AM   #35
thats harsh words coming from someone who just joined. im not being a dick, but u may want to keep personal opinions to yourself if u dont want negative feedback from others.
96 GT- Who knows what's in it.
It can Drift! DarkShadows Pictures and Videos 22 07-06-2009 06:48 AM
GT500 drift car tedness The Bar 20 06-23-2006 04:33 PM
Happy birthday to our drift god Brent The Bar 17 12-04-2005 10:54 PM
drift pics caught of me tedness Pictures and Videos 28 10-21-2005 11:57 PM
if el caminos can drift.... tedness The Bar 1 06-21-2005 10:55 AM
09:59 AM
