signal problem - Mustang Evolution
Old 04-05-2009, 10:50 AM   #1
Angry signal problem
passenger front signal frozen on, I replaced the bulbs but no luck. anyone have an idea where to go from here?
ceilingguy is offline   Reply With Quote
Old 04-05-2009, 11:56 AM   #2
Re: signal problem
the column switch might be bad, does it go off when you turn the other signal on?
Old 04-05-2009, 02:33 PM   #3
RyansQuick6's Avatar
Re: signal problem
I'd start at the relay first then work up to multi-function switch.
RyansQuick6 is offline   Reply With Quote
Old 04-05-2009, 07:30 PM   #4
Re: signal problem
Thanks for the help guys but when I opened the fuse panel inside the kick it was drenched with water. Looks like it has to go to the dealer that repaired the windshield and replaced the roof.
My wife got hit by a tire from a jackass that didn't tighten his lug nuts enough. Anyone who thinks mustangs aren't built good should see the beating this pony took.
Old 04-05-2009, 07:52 PM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: signal problem
It could be the rear bulb is burned out and that's causing the front to not flash... Unless it's always on, in which case, I'd say the water in the fuse box is probably to blame.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-06-2009, 01:37 AM   #6
Re: signal problem
What fuse box in the kick panel? it should be under the dash to the left of the column. ake pics of the water damage and call your insurance company and possibly even alawyer. Water damage can make a car a PITA for forever.
LED turn signal bulbs cterie 1996-2004 Mustang GT 1 05-07-2010 10:05 AM
96/04 combo turn signal switch Cobra GT Mustang Parts for Sale and Wanted 1 04-17-2009 08:53 AM
frozen turn signal ceilingguy Pre-2005 V6 Mustang 2 04-10-2009 01:34 AM
turn signal prob gearbanger67 Classic Mustangs 2 10-09-2007 08:37 PM
Sequental Turn signal Discount till the 9th!!! Rellik Mustang Audio & Video 2 11-10-2003 11:04 AM
11:37 AM
