Rear Differential, 1998 Mustang - Mustang Evolution
Old 04-05-2009, 07:14 PM   #1
Sam09's Avatar
Send a message via Yahoo to Sam09
Question Rear Differential, 1998 Mustang
Hey y'all,
I'm replacing the rear end in my 1998 V6 Mustang. I need to know what size is from the factory and what year models I can get a replacement out of.
Thanks so much
Sam
Sam09 is offline   Reply With Quote
Old 04-05-2009, 07:20 PM   #2
Re: Rear Differential, 1998 Mustang
it is a 7.5 inch differential and you need one from a 94-98 style as the 99-04 are a bit wider by about .75 inches per side. You can also use a GT 8.8 rear end, same fitment just stronger and has positive traction where yours does not
why are you replacing vs rebuilding or what not?
Old 04-06-2009, 01:39 AM   #3
RyansQuick6's Avatar
+1, but the new edge rear end is only .5" wider, not 3/4". It's really nice to have on an SN-95 since you can run a wider tire in the back without rubbing issues.
If you hunt around you can find a good 8.8 used for cheap, just be smart and replace all the fluid and AT LEAST the axle seals before you install it on your car.
RyansQuick6 is offline   Reply With Quote
Old 04-06-2009, 12:55 PM   #4
Sam09's Avatar
I'm replacing because that's what my dad said to look for and he's paying for it cuz i'm a bum, lmao. Thanks for your help!
1998 mustang
1998 'stang needs ALL o2 sensors and rear differential replaced xxmustang98xx Pre-2005 V6 Mustang 12 08-09-2009 10:22 PM
03:48 PM
