Engine quits - Mustang Evolution
Old 04-06-2009, 07:34 AM   #1
Engine quits
Hi all,
I have a 2000 3.8 L with a Pro Charger Supercharger. The car ran great since we bought it. Yesterday it ran great. Today it starts without giving it gas then shuts off in seconds. Why" Seems liuke it is starving for gas. Never ran it out of gas. ?? Fuel filter or something in the supercharger?
Thank you,
Ted
tmyers58 is offline   Reply With Quote
Old 04-06-2009, 04:03 PM   #2
RyansQuick6's Avatar
Re: Engine quits
fuel filter should be changed every 12k miles, so I'd start there.
RyansQuick6 is offline   Reply With Quote
Old 04-07-2009, 08:32 AM   #3
Herbstang's Avatar
Re: Engine quits
Like Ryan said fuel filter is a good starting point could also be fuel pump, Dirty MAF Etc
Old 04-17-2009, 10:49 AM   #4
Re: Engine quits
The problem resolved itself once and ran fine, but now it has started to do the same thing again. I was told it was probably a anti-theft problem that allowed the engine to be started then it stopped after only a few seconds. I tried to reset it by locking the door from the outside then unlocking it using the remote control. The theft light still blinks. How can I reset this so it will keep running? Is there a way to unhook the theft device?
Thank you,
Ted
Old 04-17-2009, 02:09 PM   #5
SaleenFiend's Avatar
Re: Engine quits
Is the engine struggling when it dies? or is it like a clean cut Kill? (as if you turned it off)
I would find it hard to believe the anti-theft would be killing the vehicle while driving or even that the vehicle would recover from this. That is not the anti-theft system's job or within its normal ability.
We need some more details.
Old 04-17-2009, 02:43 PM   #6
Re: Engine quits
The engine starts without any difficulty. Don't need to give it gas when it starts. It runs for 2 seconds then stops. It is a clean kill just as if I turned off the switch. It did this before but resolved overnight. Since then it has been driven without a problem. Now it does it again. The anti theft light on the dash is blinking. I have tried locking and unlocking the doors with the remote. I removed te theft fuse, but the light still blinks. The light on the remote blinks, so I remnoved the battery from the remote. Wil;l replace it when I get another.
Ted
Old 04-17-2009, 03:09 PM   #7
Re: Engine quits
I would look into getting your key reprogrammed. If you have a bad key or the key lost its programming it could be causing this problem. If your worried about anti-theft. Which it does sound probable.
Honestly I would have Ford look at this issue.
Vortech supercharger problems car quits running sporter 2005-2010 Mustang GT 15 11-28-2008 06:55 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
Sheehan Calls It Quits Brent The Bar 13 05-31-2007 05:11 PM
Stephen Colbert Calls it Quits Brent Pictures and Videos 16 11-09-2006 09:27 PM
11:34 AM
